简介
Here we will be removing the small michrophone in the back of the taco. This task requires removing the logic board before it may be reached.
你所需要的
Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
在这个步骤中使用的工具:Phillips #0 Screwdriver$5.49
Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
Below the logic board, the small black microphone is resting within the case.
另外一个人完成了本指南。
