跳转到主内容
加入维修社区 - 创建账户
Unresponsive keyboard fix
你所需要的
    1. Unresponsive keyboard fix, Remove the bottom cover: 步骤 1 中的图像 1,1
      • Note: These 2 screws are longer then the others.
      • Unscrew the remaining 8 screws. These are all the same length.
      添加评论
    2. Unresponsive keyboard fix, Remove the battery: 步骤 2 中的图像 1,1
      • Remove the back cover. There are no warranty stickers that need to be broken.
      • Locate the keyboard connector. It is covered with a piece of tape helping hold it in place. This tape often fails after a certain amount of time.
      • You may need to remove the battery to disconnect it. Unscrew the 3 screws holding the battery in the system.
      询问修复机器人
      添加评论
    3. Unresponsive keyboard fix, Reconnect the keyboard: 步骤 3 中的图像 1,1
      • Note: New tape should be added once reseated.
      • Remove the tape covering the connector.
      • Here on the picture you can see the connector in the unlocked position. These hold the connector in and should be completely pushed in.
      • Push the connector in. Do this until it is secure.
      • Lock the tabs that retain the keyboard connector in place.
      询问修复机器人
      添加评论
结论
Screw everything back and if you've done it right, enjoy all your keyboard keys again.
取消:我没有完成这个指南。
96等其他人完成本指南。
Francis
于11/29/12注册
1,784 声望
撰写一个指南
63指南评论
Awesome fix, thanks! This exact issue was plaguing the up and down keys on my UX31 (this is after having to RMA the thing for power issues). Be forewarned, if you are attempting this on a machine that is in sleep or hibernation mode, it has the potential to shut it off, with no visible LED lights to indicate. You can reset by holding down the power button for ~10 seconds and it should boot back up, if not, check connections again.
The LED light on the charging cable is a decent indication if something's up or not.
Jeff L - 回复 分享
Yep, this worked on my zenbook UX31A. The two white push tabs have to be fully in for the wires in the ribbon cable to contact. When u push in one, the other one pops open, so push both together.
Also, MY zenbook needed a torx T4 to unscrew the screws.
spud - 回复 分享
Great fix! My shift keys were not registering, and upon removing the back I saw the keyboard connector was indeed loose. Securing it in place fixed the problem. Thanks a lot!
Adolfo Brandes - 回复 分享
Thanks for this! I had random keys unresponsive at various times, my white connector was plugged in on one side but not the other. See-sawed it back and forth until they were both in.
I think the cause is the battery; it physically places the keyboard cable under stress. I replaced the tape with much stronger stuff but am not sure if it will be a permanent fix...
Jonathan - 回复 分享
Thanks man, you are the best!! This is a great notebook, and this problem was starting to make me hate it. Easy as cake. Wish you good fortune and the best of luck.
Saturnin Kepa - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 13
过去 30 天: 79
总计 177,707
