社区贡献指南
我们社区的一个非常棒的成员制作了本指南。它不是由 iFixit 工作人员创建的。
简介
转到步骤 1 ↓Test whether the speaker to answering the phone call works and change it if necessary. This guide work for Unihertz Atom, not Unihertz Atom XL or anything else.
I suspect that my speaker broken because of the water go into it.
You need a speaker fit unihertz atom's size. It should be 8*9*2.3mm (2~2.3mm). The seller said it work for another huawei phone too.
To find the speaker, I ask many cellphone parts sellers whether they have speakers in this size. Contact me if you can not find one; I still have 2 speakers.
See also:
- their official assembly tutorial: https://www.unihertz.com/blogs/tutorial/...
- their assembly video: https://www.youtube.com/watch?v=h7prGrJ3...
Pry open the cable interface connecting the battery and the motherboard remove the battery
Remove the screws on the camera assembly Pry open the cable interface at the connection between the camera assembly and the motherboard
you can cee the speaker for the phone call now.
Test it with a Ohmmeter. Metering its resistance between left and right metal leg. If it does not make noise while metering, it was broken.
It was pasted on the phone; remove it with a flathead screwdriver or somewhat.
put the new speaker there. for me, it work fine without glue.
put anything back.
Be careful while installing the camera part, the cable could fit even in a wrong position. If the camera does not work after reboot the phone, you may misarrange the cable.
当重新组装你的设备时,请按照说明的相反顺序进行操作。
2指南评论
@midori I see you delete the speaker's page (https://zh.ifixit.com/Item/History/speak...) , which is a very important part in this guide.
Can you explain why you do so? or where can I upload the photo of the speaker?
Hey, @midori , since you does not explain your deletion, I recover the old speaker page (speaker module for unihertz atom). Please tell me if it is not appropriate.
