跳转到主内容
加入维修社区 - 创建账户
UTStarcom CDM8945vw Logic Board Replacement
你所需要的
  1. UTStarcom CDM8945vw Logic Board Replacement, Battery: 步骤 1 中的图像 1,1
    • Push the highlighted button in the direction in which the antenna is pointing. The battery will release and pop up.
    询问修复机器人
    添加评论
  2. UTStarcom CDM8945vw Logic Board Replacement: 步骤 2 中的图像 1,1
    • Remove the battery.
    询问修复机器人
    添加评论
  3. UTStarcom CDM8945vw Logic Board Replacement, Antenna: 步骤 3 中的图像 1,1
    • Identify the antenna. It is the extendable plastic component pictured here.
    询问修复机器人
    添加评论
  4. UTStarcom CDM8945vw Logic Board Replacement: 步骤 4 中的图像 1,1
    • Twist the base in a counter-clockwise motion to unscrew the antenna.
    询问修复机器人
    添加评论
  5. UTStarcom CDM8945vw Logic Board Replacement: 步骤 5 中的图像 1,2 UTStarcom CDM8945vw Logic Board Replacement: 步骤 5 中的图像 2,2
    • The antenna should slide right out of the phone when finished.
    询问修复机器人
    添加评论
  6. UTStarcom CDM8945vw Logic Board Replacement, Speaker: 步骤 6 中的图像 1,1
    • Remove the small rubber grommet using the plastic opening tool.
    询问修复机器人
    添加评论
  7. UTStarcom CDM8945vw Logic Board Replacement: 步骤 7 中的图像 1,1
    • Remove five screws using a Phillips #00 screwdriver.
    询问修复机器人
    添加评论
  8. UTStarcom CDM8945vw Logic Board Replacement: 步骤 8 中的图像 1,1
    • Use the plastic opening tool to separate the two pieces that form the outer case of the phone.
    • Prying the two pieces apart may be difficult. Carefully apply a moderate amount of pressure when attempting to separate the two pieces or else you will risk breaking them.
    询问修复机器人
    添加评论
  9. UTStarcom CDM8945vw Logic Board Replacement: 步骤 9 中的图像 1,1
    • Remove the back piece of the outer case.
    询问修复机器人
    添加评论
  10. UTStarcom CDM8945vw Logic Board Replacement: 步骤 10 中的图像 1,1
    • Remove the speaker using a plastic opening tool.
    • Apply a small amount of force when removing the broken speaker from the motherboard. If you apply a large amount of force, you may rip out the wires and damage the motherboard.
    询问修复机器人
    添加评论
  11. UTStarcom CDM8945vw Logic Board Replacement: 步骤 11 中的图像 1,2 UTStarcom CDM8945vw Logic Board Replacement: 步骤 11 中的图像 2,2
    在这个步骤中使用的工具:
    • Remove the wire attached to the speaker from the motherboard using tweezers.
    • Apply a small amount of force when removing the wire from the motherboard. If you apply a large amount of force, you may rip out the wires and damage the motherboard.
    询问修复机器人
    添加评论
  12. UTStarcom CDM8945vw Logic Board Replacement, Logic Board: 步骤 12 中的图像 1,1
    • Detach the highlighted piece from the logic board using a plastic opening tool.
    询问修复机器人
    添加评论
  13. UTStarcom CDM8945vw Logic Board Replacement: 步骤 13 中的图像 1,2 UTStarcom CDM8945vw Logic Board Replacement: 步骤 13 中的图像 2,2
    • Remove the logic board from the anterior piece of the outer case using the plastic opening tool.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Bilal
于10/04/12注册
1 声望
撰写一个指南
团队
Cal Poly, Team 24-26, Regan Fall 2012 Cal Poly, Team 24-26, Regan Fall 2012 的会员
CPSU-REGAN-F12S24G26
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 26
总计 596
