跳转到主内容
加入维修社区 - 创建账户
USB/Auxiliary Port
你所需要的
    1. USB/Auxiliary Port, Outer Case: 步骤 1 中的图像 1,2 USB/Auxiliary Port, Outer Case: 步骤 1 中的图像 2,2
      • Using the standard metal spudger, begin by prying at the bottom of the plain rubber end cap (the end without the USB or auxiliary input).
      添加评论
    2. USB/Auxiliary Port: 步骤 2 中的图像 1,1
      • Continue prying around the end panel, prying at different points until the entire panel is out of its seating.
      • Carefully remove the end panel.
      • The tabs which connect the panel are on the short sides.
      • WARNING: you will likely cause cosmetic damage to the end cap.
      询问修复机器人
      添加评论
    3. USB/Auxiliary Port: 步骤 3 中的图像 1,1
      • Slide out the rubber foot located on the bottom of the case.
      询问修复机器人
      添加评论
    4. USB/Auxiliary Port: 步骤 4 中的图像 1,1
      • Using a T6 bit, remove the flat topped 5mm screw located on the bottom of the casing, underneath the rubber foot.
      • This is the only flat topped screw in the speaker, so keep track of which one it is.
      添加评论
    5. USB/Auxiliary Port: 步骤 5 中的图像 1,3 USB/Auxiliary Port: 步骤 5 中的图像 2,3 USB/Auxiliary Port: 步骤 5 中的图像 3,3
      • Push against the side without end cap to slide the internal components out of the case.
      • While holding the metal outset casing with one hand, press on the black inner plastic casing with your thumb.
      • It will be very difficult the first time. There is a rubber seal on the outside of the plastic inner case that creates a lot of friction with the metal outer case.
      询问修复机器人
      添加评论
    1. USB/Auxiliary Port, USB/Auxiliary Port: 步骤 6 中的图像 1,2 USB/Auxiliary Port, USB/Auxiliary Port: 步骤 6 中的图像 2,2
      • Using the standard metal spudger, carefully pry up the top 2 plastic tabs which hold the exterior button and port cover onto the interior plastic frame.
      询问修复机器人
      添加评论
    2. USB/Auxiliary Port: 步骤 7 中的图像 1,1
      • Using the classic metal spudger, pry up the bottom 2 tabs attaching the other side of the button panel.
      • It should come off after prying up the first tab.
      询问修复机器人
      添加评论
    3. USB/Auxiliary Port: 步骤 8 中的图像 1,3 USB/Auxiliary Port: 步骤 8 中的图像 2,3 USB/Auxiliary Port: 步骤 8 中的图像 3,3
      在这个步骤中使用的工具:
      • Carefully lift out the end panel.
      • Unplug both the connection ribbon and the ZIF ribbon using tweezers or your hands.
      • There is a bit of glue to hold the connection ribbon down.
      询问修复机器人
      添加评论
    4. USB/Auxiliary Port: 步骤 9 中的图像 1,1
      • Remove the 5mm T6 screw holding the port assembly onto the end cap.
      • Unlike the flat top screw holding the metal housing, these screws are roundtop.
      询问修复机器人
      添加评论
    5. USB/Auxiliary Port: 步骤 10 中的图像 1,1
      • Remove the old port assembly from the end cap.
      • Alternate Reassembly required, read on.
      添加评论
    6. USB/Auxiliary Port: 步骤 11 中的图像 1,1
      • Disconnect the Motherboard connection ribbon from the motherboard.
      • The ribbon should no longer be connected at either end.
      询问修复机器人
      添加评论
    7. USB/Auxiliary Port: 步骤 12 中的图像 1,1
      • Very carefully pull the motherboard connection ribbon through the plastic casing, removing it from the plastic casing.
      询问修复机器人
      添加评论
    8. USB/Auxiliary Port: 步骤 13 中的图像 1,1
      • Insert the connection ribbon into its ZIF connection port on the bottom of the new port assembly
      • ZIF connectors are delicate and often give beginners trouble, search for ZIF connector tips on the web.
      询问修复机器人
      添加评论
    9. USB/Auxiliary Port: 步骤 14 中的图像 1,2 USB/Auxiliary Port: 步骤 14 中的图像 2,2
      • Position the new port assembly on the end cap and reinsert the 5mm T6 screw.
      • The rubber insulation around the motherboard connector should help hold the ZIF connector in place after the screw has been reinserted.
      询问修复机器人
      添加评论
    10. USB/Auxiliary Port: 步骤 15 中的图像 1,2 USB/Auxiliary Port: 步骤 15 中的图像 2,2
      • Reconnect the button ribbon connector on the top of the port assembly.
      询问修复机器人
      添加评论
    11. USB/Auxiliary Port: 步骤 16 中的图像 1,2 USB/Auxiliary Port: 步骤 16 中的图像 2,2
      • Reconnect the endcap to the plastic housing.
      • While you reconnect the endcap to the plastic housing, carefully position the ribbon slide through the ribbon slit and into the plastic casing.
      询问修复机器人
      添加评论
    12. USB/Auxiliary Port: 步骤 17 中的图像 1,1
      • Snap the end cap back onto the inner plastic casing and reconnect the ZIF ribbon to the motherboard.
      • Finish reassembling in descending order starting at step 5.
      询问修复机器人
      添加评论
结论
To reassemble your device, follow steps 1 through 5 in reverse order.
取消:我没有完成这个指南。
5等其他人完成本指南。
Noah Sadler
于04/01/15注册
548 声望
创作了2篇指南
团队
Cal Poly, Team 12-1, Lancaster Spring 2015 Cal Poly, Team 12-1, Lancaster Spring 2015 的会员
CPSU-LANCASTER-S15S12G1
5 名成员
创作了27篇指南
1指南评论
Can anyone at all tell us where we can definitely purchase the USB/Auxiliary Port and its Motherboard to Aux Port ZIF Ribbon?
Thanks in advance.
barrysum - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 60
总计 15,979
