跳转到主内容
加入维修社区 - 创建账户
USB Cable Repair
你所需要的
    1. USB Cable Repair, USB Cable Repair: 步骤 1 中的图像 1,3 USB Cable Repair, USB Cable Repair: 步骤 1 中的图像 2,3 USB Cable Repair, USB Cable Repair: 步骤 1 中的图像 3,3
      • Remove the broken portion of the USB cable with the wire cutters.
      • You should now have two pieces of the cable left. If you had to remove the whole USB plug, you'll need a replacement plug.
      添加评论
    2. USB Cable Repair: 步骤 2 中的图像 1,3 USB Cable Repair: 步骤 2 中的图像 2,3 USB Cable Repair: 步骤 2 中的图像 3,3
      • Cut the outer cable covering with wire cutters or scissors of both cables and be careful not to cut the wires themselves.
      • Pull off the piece of cover that you've separated from the rest. You should be left with four exposed individual wires.
      • There should be four wires, and occasionally a piece of string too. If there are fewer wires, then you've clipped one off, and you need to start over.
      • If there are more than 4 wires, you probably have a USB 3.0 cable. In this case, make sure that whatever wires you'll be reconnecting are both USB 3.0.
      询问修复机器人
      添加评论
    3. USB Cable Repair: 步骤 3 中的图像 1,2 USB Cable Repair: 步骤 3 中的图像 2,2
      • Strip all the wires out from both cables using a wire stripper. You'll need about three quarters of an inch of exposed copper wire.
      • If you don't have a wire stripper, you can strip the wires the same way as you exposed these wires. Gently cut the outer insulation, then pull off the insulation.
      • When stripping wires, do not cut or damage the copper wires. If you do damage the wire, cut off the damaged portion and try again.
      询问修复机器人
      添加评论
    4. USB Cable Repair: 步骤 4 中的图像 1,2 USB Cable Repair: 步骤 4 中的图像 2,2
      在这个步骤中使用的工具:
      FixHub Smart Soldering Iron
      $79.95
      添加评论
    5. USB Cable Repair: 步骤 5 中的图像 1,3 USB Cable Repair: 步骤 5 中的图像 2,3 USB Cable Repair: 步骤 5 中的图像 3,3
      • Wrap each wire in electrical tape and make sure that there is no exposed copper showing.
      添加评论
    6. USB Cable Repair: 步骤 6 中的图像 1,2 USB Cable Repair: 步骤 6 中的图像 2,2
      • Wrap all the wires and both cables together in electrical tape to connect everything back into one cable and so it lasts longer.
      添加评论
结论
Once your device is assembled and taped up then the repair is done and you can go back and do this multiple times.
取消:我没有完成这个指南。
41等其他人完成本指南。
David
于01/16/13注册
1,316 声望
创作了4篇指南
团队
Cal Poly, Team 18-36, Regan Winter 2013 Cal Poly, Team 18-36, Regan Winter 2013 的会员
CPSU-REGAN-W13S18G36
3 名成员
创作了30篇指南
7指南评论
thanks you verb much
obito uchiha - 回复 分享
very i meant
What if it has a wire shield around it? Like crazy silver wires wrapped around it?
Bethany Marshall - 回复 分享
Then slowly wnwrap it not to remove it. And when u have repaired wires and taped them re wrap with silver shielding if it does have shielding it best to add a step to the repair and tbats to add a short section of shrink tubeing just big enough to cover spliced section and shielding. Once shielding is wrapped slid tubeing over repaired section and apply heat a hairdryer on high heat will work as well.
kotanwolf - 回复 分享
i tried solding the same wires but it still do not work
Faizan Ali - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 32
过去 7 天: 217
过去 30 天: 960
总计 178,433
