跳转到主内容
Turtle Beach Recon 200 Gen 2 Audio Repair
你所需要的
  1. Turtle Beach Recon 200 Gen 2 Audio Repair, Turtle Beach Recon 200 Gen 2 Audio Repair: 步骤 1 中的图像 1,2 Turtle Beach Recon 200 Gen 2 Audio Repair, Turtle Beach Recon 200 Gen 2 Audio Repair: 步骤 1 中的图像 2,2
    • Before you begin, power off your headset and unplug it from the charging cable.
    • Place the headset on a flat surface.
    • Grab the outer layer of the cushion and gently pull each ear cup off the headset.
  2. Turtle Beach Recon 200 Gen 2 Audio Repair: 步骤 2 中的图像 1,3 Turtle Beach Recon 200 Gen 2 Audio Repair: 步骤 2 中的图像 2,3 Turtle Beach Recon 200 Gen 2 Audio Repair: 步骤 2 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove three screws from each speaker cover.
    • Use proper screwdriver practices. If you strip a screw, review this guide for tips on how to remove a stripped screw.
    • Place the screws in a secure area. You will need them for reassembly.
  3. Turtle Beach Recon 200 Gen 2 Audio Repair: 步骤 3 中的图像 1,3 Turtle Beach Recon 200 Gen 2 Audio Repair: 步骤 3 中的图像 2,3 Turtle Beach Recon 200 Gen 2 Audio Repair: 步骤 3 中的图像 3,3
    • Use a spudger to gently pry the speakers from the headset.
    • The speaker is connected to the motherboard by a cable so do not pull the speaker off or it will rip the wire and further damage your headphones.
    • Do not push the prying tool inside the cups, or you could damage the internal components.
  4. Turtle Beach Recon 200 Gen 2 Audio Repair: 步骤 4 中的图像 1,2 Turtle Beach Recon 200 Gen 2 Audio Repair: 步骤 4 中的图像 2,2
    • Set the speaker to the side without pulling the wires or cables.
    • Check if any dust has gotten into the headset.
    • If so, use a dust blower and/or ESD safe cleaning brush to clean off the dust.
    • If a wire is broken or ripped, use tweezers to hold it and identity where the wire is meant to be.
    • Do not attempt to rip or pull any damaged or exposed wire(s).
  5. Turtle Beach Recon 200 Gen 2 Audio Repair: 步骤 5 中的图像 1,2 Turtle Beach Recon 200 Gen 2 Audio Repair: 步骤 5 中的图像 2,2
    • Use the multimeter to check for any outage or shortage of current.
    • Check any and every wire and pins you think are faulty that could be the cause of the issue.
    • Most multimeter devices have sharp points, be careful when checking for current. Touch the surface as lightly as possible.
  6. Turtle Beach Recon 200 Gen 2 Audio Repair: 步骤 6 中的图像 1,2 Turtle Beach Recon 200 Gen 2 Audio Repair: 步骤 6 中的图像 2,2
    • Use a soldering iron to re-solder any wires that have detached from the motherboard.
    • Keep your hands as steady as possible and ensure that the wires are attached to the correct solder joint.
    • The solder might release an odd smell. If possible, wear a mask to avoid inhaling fumes.
    • The end point of the soldering kit will be very hot, do not touch it with your bare hands.
  7. Turtle Beach Recon 200 Gen 2 Audio Repair: 步骤 7 中的图像 1,3 Turtle Beach Recon 200 Gen 2 Audio Repair: 步骤 7 中的图像 2,3 Turtle Beach Recon 200 Gen 2 Audio Repair: 步骤 7 中的图像 3,3
    • Test the headset to ensure everything is working. Plug the headset into any device with a AUX input.
    • Test the audio on a low volume setting and slowly raise it to full volume.
    • Replace the speakers.
    • Make sure they are is sitting correctly on the headset so you can replace the screws without a problem.
结论
另外一个人完成了本指南。
David Valadez
于03/05/24注册
157 声望
撰写一个指南
团队
CSU Los Angeles, Team 7-4, Grodsky Spring 2024 CSU Los Angeles, Team 7-4, Grodsky Spring 2024 的会员
CSULA-GRODSKY-S24S7G4
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 22
总计 80
