跳转到主内容
加入维修社区 - 创建账户
Turtle Beach Elite Pro Right Speaker Replacement
你所需要的
    1. Turtle Beach Elite Pro Right Speaker Replacement, Ear Cushion: 步骤 1 中的图像 1,1
      • Firmly pinch ear cushion between thumb and forefinger.
      • Using the hand not holding the ear cushion, grasp the orange plate that is below the ear cushion.
      • If the black rubber lining on the orange plate is grasped, then the rubber lining on the ear piece may tear.
      询问修复机器人
      添加评论
    2. Turtle Beach Elite Pro Right Speaker Replacement: 步骤 2 中的图像 1,2 Turtle Beach Elite Pro Right Speaker Replacement: 步骤 2 中的图像 2,2
      • Rotate ear cushion counter-clockwise about half an inch.
      • The ear cushion should audibly snap out of place.
      • After it has audibly snapped out of place, lift the ear cushion off of the device.
      • During reassembly, rotate the ear cushion clockwise.
      询问修复机器人
      添加评论
    3. Turtle Beach Elite Pro Right Speaker Replacement: 步骤 3 中的图像 1,2 Turtle Beach Elite Pro Right Speaker Replacement: 步骤 3 中的图像 2,2
      • Using the new cushion, align the pegs located on both the orange plate and ear cushion.
      • Make sure that both the ear cushion and the orange plate have the same designation.
      • Once the pegs are aligned, push the new ear cushion in place.
      询问修复机器人
      添加评论
    1. Turtle Beach Elite Pro Right Speaker Replacement, Right Speaker: 步骤 4 中的图像 1,1
      • Remove the right ear cushion.
      • The right ear piece does not have any additional attachments.
      询问修复机器人
      添加评论
    2. Turtle Beach Elite Pro Right Speaker Replacement: 步骤 5 中的图像 1,1
      • Using the Phillips #0 screwdriver, remove the 6.0 mm screws on the orange plate.
      询问修复机器人
      添加评论
    3. Turtle Beach Elite Pro Right Speaker Replacement: 步骤 6 中的图像 1,2 Turtle Beach Elite Pro Right Speaker Replacement: 步骤 6 中的图像 2,2
      • Use the opening tool to separate the orange plate from the black base plate.
      • Focus on the wires that are connected to the speaker.
      询问修复机器人
      添加评论
    4. Turtle Beach Elite Pro Right Speaker Replacement: 步骤 7 中的图像 1,1
      • Cut the two wires that are attached to the speaker.
      • Cut the wires as close to the speaker as possible. These wires will be used in the next step.
      询问修复机器人
      添加评论
    5. Turtle Beach Elite Pro Right Speaker Replacement: 步骤 8 中的图像 1,2 Turtle Beach Elite Pro Right Speaker Replacement: 步骤 8 中的图像 2,2
      • Replace the old speaker with the new speaker.
      • Using the soldering iron, solder the wires to the new speaker.
      • Make sure to solder the wires to their original locations on the speaker.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Baylor, Team S5-G1, Williams Spring 2017 Baylor, Team S5-G1, Williams Spring 2017 的会员
BU-WILLIAMS-S17S5G1
3 名成员
创作了21篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 34
总计 1,312
