跳转到主内容
加入维修社区 - 创建账户
Turtle Beach Elite Pro Left Speaker Replacement
你所需要的
    1. Turtle Beach Elite Pro Left Speaker  Replacement, Ear Cushion: 步骤 1 中的图像 1,1
      • Firmly pinch ear cushion between thumb and forefinger.
      • Using the hand not holding the ear cushion, grasp the orange plate that is below the ear cushion.
      • If the black rubber lining on the orange plate is grasped, then the rubber lining on the ear piece may tear.
      询问修复机器人
      添加评论
    2. Turtle Beach Elite Pro Left Speaker  Replacement: 步骤 2 中的图像 1,2 Turtle Beach Elite Pro Left Speaker  Replacement: 步骤 2 中的图像 2,2
      • Rotate ear cushion counter-clockwise about half an inch.
      • The ear cushion should audibly snap out of place.
      • After it has audibly snapped out of place, lift the ear cushion off of the device.
      • During reassembly, rotate the ear cushion clockwise.
      询问修复机器人
      添加评论
    3. Turtle Beach Elite Pro Left Speaker  Replacement: 步骤 3 中的图像 1,2 Turtle Beach Elite Pro Left Speaker  Replacement: 步骤 3 中的图像 2,2
      • Using the new cushion, align the pegs located on both the orange plate and ear cushion.
      • Make sure that both the ear cushion and the orange plate have the same designation.
      • Once the pegs are aligned, push the new ear cushion in place.
      询问修复机器人
      添加评论
    1. Turtle Beach Elite Pro Left Speaker  Replacement, Left Speaker: 步骤 4 中的图像 1,1
      • Remove the left ear cushion completely from the headset.
      • The left ear cushion will be on the side of the headset where the microphone and audio control is attached.
      询问修复机器人
      添加评论
    2. Turtle Beach Elite Pro Left Speaker  Replacement: 步骤 5 中的图像 1,2 Turtle Beach Elite Pro Left Speaker  Replacement: 步骤 5 中的图像 2,2
      • Using the Phillips #0 screwdriver, remove the 6.0 mm screws on the orange plate.
      询问修复机器人
      添加评论
    3. Turtle Beach Elite Pro Left Speaker  Replacement: 步骤 6 中的图像 1,2 Turtle Beach Elite Pro Left Speaker  Replacement: 步骤 6 中的图像 2,2
      • Use the opening tool to separate the orange plate from the black base plate.
      • Focus on the wires that are connected to the speaker.
      询问修复机器人
      添加评论
    4. Turtle Beach Elite Pro Left Speaker  Replacement: 步骤 7 中的图像 1,1
      • Using wire cutters, cut the two wires that are attached to the speaker.
      • Make sure to cut the wires as close to the speaker as possible, because these wires will be used in the next step.
      询问修复机器人
      添加评论
    5. Turtle Beach Elite Pro Left Speaker  Replacement: 步骤 8 中的图像 1,2 Turtle Beach Elite Pro Left Speaker  Replacement: 步骤 8 中的图像 2,2
      • Replace the old speaker with the new speaker.
      • Using the soldering iron, solder the wires to the new speaker.
      • Make sure to solder the wires to their original locations on the speaker.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Baylor, Team S5-G1, Williams Spring 2017 Baylor, Team S5-G1, Williams Spring 2017 的会员
BU-WILLIAMS-S17S5G1
3 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 37
总计 3,679
