跳转到主内容
加入维修社区 - 创建账户
Trunk LED Tailgate Strip Light Installation
你所需要的
    1. Trunk LED Tailgate Strip Light Installation, Cleaning: 步骤 1 中的图像 1,2 Trunk LED Tailgate Strip Light Installation, Cleaning: 步骤 1 中的图像 2,2
      • Thoroughly clean the surface where you'll be applying the trunk LED tail gate lamp.
      • Use soap and water to scrub the area clean since that place is normally dirty.
      询问修复机器人
      添加评论
    2. Trunk LED Tailgate Strip Light Installation, Mounting time: 步骤 2 中的图像 1,2 Trunk LED Tailgate Strip Light Installation, Mounting time: 步骤 2 中的图像 2,2
      • Carefully measure beforehand where you're going to attach the LED strip so it looks even.
      • The LED tailgate strip is designed to be a little bit shorter than the trunk tailgate.
      • Straighten the LED strip and peel adhesive.
      • OPTIONAL: The package includes 4 mounting brackets with screws. You can use these to further secure the LED tailgate lights.
      询问修复机器人
      添加评论
    3. Trunk LED Tailgate Strip Light Installation, Wire tapping: 步骤 3 中的图像 1,3 Trunk LED Tailgate Strip Light Installation, Wire tapping: 步骤 3 中的图像 2,3 Trunk LED Tailgate Strip Light Installation, Wire tapping: 步骤 3 中的图像 3,3
      • Tap reverse light wire.
      • You will need to remove either side of the tail light to locate the reverse light.
      • Use a T-tap to tap the reverse light wire from the tailgate LED strip to positive.
      询问修复机器人
      添加评论
    4. Trunk LED Tailgate Strip Light Installation, Find the connector: 步骤 4 中的图像 1,2 Trunk LED Tailgate Strip Light Installation, Find the connector: 步骤 4 中的图像 2,2
      • This is the trailer light connector. You can see: ground, brake, left signal, right signal - plug that into stock trailer light connector.
      • You will find the trailer light connector near the tow hitch.
      添加评论
    5. Trunk LED Tailgate Strip Light Installation, Test and enjoy: 步骤 5 中的图像 1,3 Trunk LED Tailgate Strip Light Installation, Test and enjoy: 步骤 5 中的图像 2,3 Trunk LED Tailgate Strip Light Installation, Test and enjoy: 步骤 5 中的图像 3,3
      • Hide the wires or zip-tie them.
      • Check the trunk LED tailgate lamp to make sure everything works.
      添加评论
结论
You're now on your way to being the coolest truck on the road with your new trunk LED tailgate strip lights!
取消:我没有完成这个指南。
5等其他人完成本指南。
Eric Wu
于01/21/15注册
3,600 声望
创作了23篇指南
21指南评论
Should my light bar come on with my headlights they worked without the headlights but when I turn headlights on they don't work what's wrong
Anthony Carter - 回复 分享
did you get a answer to your problem because I'm having the same problem
marshallsdawgs07 - 回复 分享
Anyone have the answer to this problem yet?
Trevor G - 回复 分享
I'm having the same problem!
Richie - 回复 分享
I bought a led third brake below the tailgate and i have five wires on the led light.what is the wiring diagram for it
Spencer Sherrod - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 13
过去 30 天: 117
总计 44,646
