跳转到主内容
加入维修社区 - 创建账户
Trio STEALTH-9 Back Cover Replacement
你所需要的
    1. Trio STEALTH-9 Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,1
      • Remove the two Phillips #00 screws on the side of the tablet.
      询问修复机器人
      添加评论
    2. Trio STEALTH-9 Back Cover Replacement: 步骤 2 中的图像 1,1
      • Take one of the plastic opening tools and wedge it in the middle of the tablet, starting on the USB Port side.
      • Holding the tool in place, take one of the 6 plastic opening picks and slide it across the opening you made with the opening tool.
      询问修复机器人
      添加评论
    3. Trio STEALTH-9 Back Cover Replacement: 步骤 3 中的图像 1,1
      • Continue going around the tablet sides with the plastic pick, being sure that you are maintaining the openings you made with either your hand or the opening tool.
      • You will notice some popping as you go around with the pick. Don't worry, this is completely normal.
      询问修复机器人
      添加评论
    4. Trio STEALTH-9 Back Cover Replacement: 步骤 4 中的图像 1,1
      • Remove the back cover of the tablet to reveal the internals.
      • To replace, pinch each of the ends together until all four sides are closed.
      询问修复机器人
      添加评论
结论
To reassemble your device, follow these instructions in reverse order with your replacement cover!
取消:我没有完成这个指南。
2等其他人完成本指南。
Mei Liang
于01/29/15注册
228 声望
创作了2篇指南
团队
Clemson, Team 15-5, Shirley Winter 2015 Clemson, Team 15-5, Shirley Winter 2015 的会员
CLEM-SHIRLEY-W15S15G5
4 名成员
创作了10篇指南
2指南评论
Tengo.una y costo tiene el.displey
eliehtmaria - 回复 分享
Deseo.saber el.c
eliehtmaria - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 30
总计 1,550
