跳转到主内容
加入维修社区 - 创建账户
Trio AXS 3G Screen Replacement
你所需要的
  1. Trio AXS 3G Screen Replacement, Back Case: 步骤 1 中的图像 1,1
    • On the back of the device there is a white SD card case that shelters the screws that attach the back panel to the tablet.
    • Use your thumbs to slide up and off the small SD card case.
    询问修复机器人
    添加评论
  2. Trio AXS 3G Screen Replacement: 步骤 2 中的图像 1,2 Trio AXS 3G Screen Replacement: 步骤 2 中的图像 2,2
    • Using the Phillips Head #000, unscrew the 5 4mm and 3mm screws at the top.
    询问修复机器人
    添加评论
  3. Trio AXS 3G Screen Replacement: 步骤 3 中的图像 1,1
    • Insert a plastic opening tool between the back panel and the front of the tablet, and gently pry it away from the tablet.
    • Do not pry too hard as the screen is fragile and might crack.
    • It is best to start at the bottom of the tablet when prying the back panel off.
    • The volume piece will also dislodge when the back panel is removed.
    询问修复机器人
    添加评论
  4. Trio AXS 3G Screen Replacement, Screen: 步骤 4 中的图像 1,1
    • The motherboard and battery will have to be removed to expose the metal panel underneath.
    询问修复机器人
    添加评论
  5. Trio AXS 3G Screen Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    • Use the plastic card to pry the battery away from the device.
    • The battery is attached to the tablet by glue.
    询问修复机器人
    添加评论
  6. Trio AXS 3G Screen Replacement: 步骤 6 中的图像 1,1
    • Peel off the battery from the device and set aside.
    • The battery is connected to the motherboard by two wires. Be careful not to sever the connection.
    询问修复机器人
    添加评论
  7. Trio AXS 3G Screen Replacement: 步骤 7 中的图像 1,1
    • Using a #000 screwdriver, unscrew the five 4mm and 3 mm screws connecting the top portion of the motherboard to the device.
    询问修复机器人
    添加评论
  8. Trio AXS 3G Screen Replacement: 步骤 8 中的图像 1,1
    • Disconnect the silver tape that attaches the motherboard to the metal panel.
    询问修复机器人
    添加评论
  9. Trio AXS 3G Screen Replacement: 步骤 9 中的图像 1,1
    • Disconnect the ribbon from the bottom portion of the motherboard.
    询问修复机器人
    添加评论
  10. Trio AXS 3G Screen Replacement: 步骤 10 中的图像 1,1
    • Remove the motherboard and set aside.
    询问修复机器人
    添加评论
  11. Trio AXS 3G Screen Replacement: 步骤 11 中的图像 1,1
    • The smaller portion of the motherboard is located at the bottom with the speaker.
    • Using a #000 screwdriver, unscrew the three 3 mm screws that fasten the smaller segment of the motherboard to the tablet.
    询问修复机器人
    添加评论
  12. Trio AXS 3G Screen Replacement: 步骤 12 中的图像 1,2 Trio AXS 3G Screen Replacement: 步骤 12 中的图像 2,2
    • Located towards the bottom, carefully remove the yellow film.
    询问修复机器人
    添加评论
  13. Trio AXS 3G Screen Replacement: 步骤 13 中的图像 1,1
    • Gently disconnect the small ribbon found underneath the film.
    询问修复机器人
    添加评论
  14. Trio AXS 3G Screen Replacement: 步骤 14 中的图像 1,1
    • There is another connection found underneath this portion of the motherboard.
    • Lifting up the motherboard, disconnect the second ribbon found underneath.
    询问修复机器人
    添加评论
  15. Trio AXS 3G Screen Replacement: 步骤 15 中的图像 1,1
    • Unscrew the two 4 mm #000 screws.
    询问修复机器人
    添加评论
  16. Trio AXS 3G Screen Replacement: 步骤 16 中的图像 1,1
    • Remove the speaker and bottom portion of the motherboard.
    询问修复机器人
    添加评论
  17. Trio AXS 3G Screen Replacement: 步骤 17 中的图像 1,1
    • At this stage, almost all inside components should be removed (as shown).
    • Using a screwdriver size #000, remove the four 4 mm screws found at each corner of the metal panel if you haven't gotten them already.
    询问修复机器人
    添加评论
  18. Trio AXS 3G Screen Replacement: 步骤 18 中的图像 1,3 Trio AXS 3G Screen Replacement: 步骤 18 中的图像 2,3 Trio AXS 3G Screen Replacement: 步骤 18 中的图像 3,3
    • Use the plastic card to separate the metal panel from the screen component.
    询问修复机器人
    添加评论
  19. Trio AXS 3G Screen Replacement: 步骤 19 中的图像 1,1
    • Separate memory card from screen.
    询问修复机器人
    添加评论
  20. Trio AXS 3G Screen Replacement: 步骤 20 中的图像 1,2 Trio AXS 3G Screen Replacement: 步骤 20 中的图像 2,2
    • Use the plastic card to separate screen component from front panel.
    询问修复机器人
    添加评论
  21. Trio AXS 3G Screen Replacement: 步骤 21 中的图像 1,1
    • Use the plastic card to separate the glass from the front panel.
    • Once the glass is removed, the new glass can be fitted to the front panel.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 22
总计 1,312
