跳转到主内容
加入维修社区 - 创建账户
Trio AXS 3G Battery Replacement
你所需要的
  1. Trio AXS 3G Battery Replacement, Back Case: 步骤 1 中的图像 1,1
    • On the back of the device there is a white SD card case that shelters the screws that attach the back panel to the tablet.
    • Use your thumbs to slide up and off the small SD card case.
    询问修复机器人
    添加评论
  2. Trio AXS 3G Battery Replacement: 步骤 2 中的图像 1,2 Trio AXS 3G Battery Replacement: 步骤 2 中的图像 2,2
    • Using the Phillips Head #000, unscrew the 5 4mm and 3mm screws at the top.
    询问修复机器人
    添加评论
  3. Trio AXS 3G Battery Replacement: 步骤 3 中的图像 1,1
    • Insert a plastic opening tool between the back panel and the front of the tablet, and gently pry it away from the tablet.
    • Do not pry too hard as the screen is fragile and might crack.
    • It is best to start at the bottom of the tablet when prying the back panel off.
    • The volume piece will also dislodge when the back panel is removed.
    询问修复机器人
    添加评论
  4. Trio AXS 3G Battery Replacement, Battery: 步骤 4 中的图像 1,1
    • The battery is the large, silver square inside the tablet. It is connected to the motherboard by two wires.
    询问修复机器人
    添加评论
  5. Trio AXS 3G Battery Replacement: 步骤 5 中的图像 1,1
    • Use the soldering iron to remove the two metal ends that connect the battery to the motherboard.
    询问修复机器人
    添加评论
  6. Trio AXS 3G Battery Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    • Use the plastic card to pry the battery away from the device.
    • The battery is attached to the tablet by glue.
    询问修复机器人
    添加评论
  7. Trio AXS 3G Battery Replacement: 步骤 7 中的图像 1,1
    • Peel off the battery from the device to completely remove it.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
2指南评论
where can i buy a battery replacement? can it work without a battery?
millie abanilla - 回复 分享
where can you buy a replacement battery
J W - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 28
总计 1,627
