跳转到主内容
加入维修社区 - 创建账户
Trek 820 Front Wheel Removal
    1. Trek 820 Front Wheel Removal, Front Wheel: 步骤 1 中的图像 1,2 Trek 820 Front Wheel Removal, Front Wheel: 步骤 1 中的图像 2,2
      • Facing your bike, straddle your front wheel between your knees.
      • Locate the front brake at the top of the fork. It will more than likely look like the picture on your left.
      • Since the tire is normally wider than the space between the brake pads, you must first release the tension in the brake wire. To do this, run your right hand under both brake calipers and push them inwards towards one another.
      询问修复机器人
      添加评论
    2. Trek 820 Front Wheel Removal: 步骤 2 中的图像 1,2 Trek 820 Front Wheel Removal: 步骤 2 中的图像 2,2
      • With the brake wire sufficiently loosened, unhook the metal tube that contains the brake wire (called the noodle) from the brake wire holder using your left hand.
      • The brake will now be open wide enough to permit removal of the wheel.
      询问修复机器人
      添加评论
    3. Trek 820 Front Wheel Removal: 步骤 3 中的图像 1,2 Trek 820 Front Wheel Removal: 步骤 3 中的图像 2,2
      • Find the quick release lever on the outside of the bike's fork on the right hand side. Flip the lever down and turn the lever counter clockwise, loosening the lever until it comes off.
      询问修复机器人
      添加评论
    4. Trek 820 Front Wheel Removal: 步骤 4 中的图像 1,1
      • After the quick release lever is removed, the wheel can be separated from the front fork.
      询问修复机器人
      添加评论
      • In reassembling the wheel to the bike, perform the steps in reverse order.
      • With the axle all the way into the fork slots, tighten the quick release lever into the fork end securely. It should take a modest amount of force applied to tighten the axle to the fork.
      • Squeeze the brake calipers together and return the cable noodle back into the holder.
      • Make sure you go back, and check to make sure its snug so that the wheel has no way of coming back off.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
团队
Cal Poly, Team 1-1, Propen Fall 2012 Cal Poly, Team 1-1, Propen Fall 2012 的会员
CPSU-PROPEN-F12S1G1
5 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 22
过去 30 天: 84
总计 13,488
