跳转到主内容
加入维修社区 - 创建账户
Transforming High-Rise Pants into Low-Rise Style by Hand
你所需要的
    1. Transforming High-Rise Pants into Low-Rise Style by Hand, Transforming High-Rise Pants into Low-Rise Style by Hand: 步骤 1 中的图像 1,2 Transforming High-Rise Pants into Low-Rise Style by Hand, Transforming High-Rise Pants into Low-Rise Style by Hand: 步骤 1 中的图像 2,2
      • Begin by turning pants inside out and laying flat.
      询问修复机器人
      添加评论
    2. Transforming High-Rise Pants into Low-Rise Style by Hand: 步骤 2 中的图像 1,3 Transforming High-Rise Pants into Low-Rise Style by Hand: 步骤 2 中的图像 2,3 Transforming High-Rise Pants into Low-Rise Style by Hand: 步骤 2 中的图像 3,3
      • Line up the seams to match on both sides.
      • Mark where you would like the new bottom of your pants to sit.
      • Using a straight edge, mark a line going down from the initial mark down to the leg of the pants.
      询问修复机器人
      添加评论
    3. Transforming High-Rise Pants into Low-Rise Style by Hand: 步骤 3 中的图像 1,3 Transforming High-Rise Pants into Low-Rise Style by Hand: 步骤 3 中的图像 2,3 Transforming High-Rise Pants into Low-Rise Style by Hand: 步骤 3 中的图像 3,3
      • After the guide lines have been drawn out, cut off the fabric marked off leaving roughly 1cm for seam allowance.
      询问修复机器人
      添加评论
    4. Transforming High-Rise Pants into Low-Rise Style by Hand: 步骤 4 中的图像 1,2 Transforming High-Rise Pants into Low-Rise Style by Hand: 步骤 4 中的图像 2,2
      • Line up the fabric on both sides and pin together keeping the fabric in line.
      询问修复机器人
      添加评论
    5. Transforming High-Rise Pants into Low-Rise Style by Hand: 步骤 5 中的图像 1,3 Transforming High-Rise Pants into Low-Rise Style by Hand: 步骤 5 中的图像 2,3 Transforming High-Rise Pants into Low-Rise Style by Hand: 步骤 5 中的图像 3,3
      • Thread your needle with a thread close to the color of the pants you are altering.
      • Tie the ends of the thread into a knot large enough to not go through the fabric being sewn.
      询问修复机器人
      添加评论
    6. Transforming High-Rise Pants into Low-Rise Style by Hand: 步骤 6 中的图像 1,2 Transforming High-Rise Pants into Low-Rise Style by Hand: 步骤 6 中的图像 2,2
      • Insert the needle into the bottom of the marked line to begin your stitch.
      询问修复机器人
      添加评论
    7. Transforming High-Rise Pants into Low-Rise Style by Hand: 步骤 7 中的图像 1,3 Transforming High-Rise Pants into Low-Rise Style by Hand: 步骤 7 中的图像 2,3 Transforming High-Rise Pants into Low-Rise Style by Hand: 步骤 7 中的图像 3,3
      • Pull thread through the fabric and reinsert leaving about 1mm in between.
      • Insert the needle on the back side of the fabric about 1mm away from the previous stitch.
      • Insert the needle back into the initial stitch to create a backstitch.
      询问修复机器人
      添加评论
    8. Transforming High-Rise Pants into Low-Rise Style by Hand: 步骤 8 中的图像 1,3 Transforming High-Rise Pants into Low-Rise Style by Hand: 步骤 8 中的图像 2,3 Transforming High-Rise Pants into Low-Rise Style by Hand: 步骤 8 中的图像 3,3
      • Continue backstitching all around the marked line.
      • Tie off the thread once you reach the end by tying a knot into the final stitch.
      询问修复机器人
      添加评论
    9. Transforming High-Rise Pants into Low-Rise Style by Hand: 步骤 9 中的图像 1,2 Transforming High-Rise Pants into Low-Rise Style by Hand: 步骤 9 中的图像 2,2
      • Flip pants right side out and enjoy your new low-rise pants!
      询问修复机器人
      添加评论
终点
取消:我没有完成这个指南。
Addison Cavenee
于01/21/25注册
169 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 66
总计 792
