跳转到主内容
加入维修社区 - 创建账户
TotalPond Pond Pump O-ring Replacement
    1. TotalPond Pond Pump O-ring Replacement, Inlet Screen Removal: 步骤 1 中的图像 1,3 TotalPond Pond Pump O-ring Replacement, Inlet Screen Removal: 步骤 1 中的图像 2,3 TotalPond Pond Pump O-ring Replacement, Inlet Screen Removal: 步骤 1 中的图像 3,3
      • Hold the inlet screen and rotate it counterclockwise to unscrew it. It is helpful to remove the inlet screen so that it is not damaged during the replacement process.
      询问修复机器人
      添加评论
    2. TotalPond Pond Pump O-ring Replacement, Impeller Assembly Detachment: 步骤 2 中的图像 1,2 TotalPond Pond Pump O-ring Replacement, Impeller Assembly Detachment: 步骤 2 中的图像 2,2
      • Firmly hold the pump block with one hand and the impeller housing with the other hand. Rotate impeller housing counterclockwise until it is released.
      询问修复机器人
      添加评论
    3. TotalPond Pond Pump O-ring Replacement, Impeller Assembly Removal: 步骤 3 中的图像 1,1
      • Carefully pull out the impeller. A magnetic pull should be felt.
      询问修复机器人
      添加评论
    4. TotalPond Pond Pump O-ring Replacement, O-Ring Removal: 步骤 4 中的图像 1,2 TotalPond Pond Pump O-ring Replacement, O-Ring Removal: 步骤 4 中的图像 2,2
      • While holding the pump with one hand, pinch the O-ring and slide it upward with your free hand so that a portion of the ring is lifted.
      询问修复机器人
      添加评论
    5. TotalPond Pond Pump O-ring Replacement, O-Ring Removal continued: 步骤 5 中的图像 1,2 TotalPond Pond Pump O-ring Replacement, O-Ring Removal continued: 步骤 5 中的图像 2,2
      • With one finger from the hand that is holding the pump, push the lifted portion of the ring forward until it is completely detached from the pump.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
USF Tampa, Team 3-6, Hickman Winter 2015 USF Tampa, Team 3-6, Hickman Winter 2015 的会员
USFT-HICKMAN-W15S3G6
4 名成员
创作了25篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 29
总计 1,086
