简介
This replacement guide will walk you through the steps needed to replace the battery on your Toshiba Encore Mini and will serve as the first step for any other replacements you may need to perform. Prior to removing any parts on your device, backing-up all data and photos to an external storage device is recommended. In this guide, you will be removing the following:
- Back Cover
- Battery
你所需要的
Using the flat end of the spudger, gently pry open the back case from the rest of the device.
5等其他人完成本指南。
