跳转到主内容
加入维修社区 - 创建账户
Top Cover
你所需要的
  1. Top Cover, Remove screws: 步骤 1 中的图像 1,1
    • Remove six Philips #2 screws from the bottom of the case.
    • REASSEMBLY CAUTION: To prevent thread stripping during reassembly, turn screws backwards slowly until you feel the screw thread drop into the original plastic thread, and only then, tighten screw normally but lightly - you're working with 20+ year-old plastics.
    询问修复机器人
    添加评论
  2. Top Cover, Disconnect top cover ribbon cable: 步骤 2 中的图像 1,1
    • Carefully fold the top and bottom open, revealing a ribbon cable connecting the two halves.
    • Unlock and disconnect the ribbon cable. Unlock by pulling the lock lever evenly on both sides, parallel to the board surface (not lift/pivot), in the direction of the ribbon cable.
    • When this ZIF (Zero Insertion Force) connector is properly unlocked, the ribbon cable should just fall right out of the socket (no need to pull with any strength).
    询问修复机器人
    添加评论
  3. Top Cover, Remove RF shield: 步骤 3 中的图像 1,2 Top Cover, Remove RF shield: 步骤 3 中的图像 2,2
    • Simply lift the RF shield off the unit.
    • When reinstalling, take note of the 6 fork-like interlocking clips around the edge of the shield, which should engage with the original positions.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Matt Falcon
于05/09/15注册
2,773 声望
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 33
总计 281
