跳转到主内容
加入维修社区 - 创建账户
TomTom VIA 1530 TM Back Replacement
你所需要的
    1. TomTom VIA 1530 TM Back Replacement, Back: 步骤 1 中的图像 1,2 TomTom VIA 1530 TM Back Replacement, Back: 步骤 1 中的图像 2,2
      • Position the device so that the underside is facing up.
      • Tilt the EasyPort Mount slightly upward and rotate it counterclockwise 180 degrees from the initial position.
      • Firmly grab the EasyPort Mount and remove it.
      • If it does not dislodge easily, gently twist the EasyPort Mount, applying increasing pressure until it does.
      询问修复机器人
      添加评论
    2. TomTom VIA 1530 TM Back Replacement: 步骤 2 中的图像 1,2 TomTom VIA 1530 TM Back Replacement: 步骤 2 中的图像 2,2
      • Turn the device 180 degrees so the screw in the EasyPort Mount compartment is on top.
      • Remove the 2mm screw beneath the EasyPort Mount compartment with the Torx T-5 head Screwdriver.
      询问修复机器人
      添加评论
    3. TomTom VIA 1530 TM Back Replacement: 步骤 3 中的图像 1,2 TomTom VIA 1530 TM Back Replacement: 步骤 3 中的图像 2,2
      • Flip the device over so that the screen is facing up.
      • Wedge the plastic opening tool between the top and bottom of the device's frame, gently sliding it around the outside edge.
      • It may be easier to start at one of the corners.
      • The gold ribbon cable connecting the screen to the motherboard is fragile and tears easily.
      • This specific device's ribbon cable is torn.
      询问修复机器人
      添加评论
    4. TomTom VIA 1530 TM Back Replacement: 步骤 4 中的图像 1,2 TomTom VIA 1530 TM Back Replacement: 步骤 4 中的图像 2,2
      • Carefully slide the screen forward, revealing the lower portion of the motherboard.
      • Remove the 3.6mm screw using the JIS #00 Screwdriver.
      • Rotate the device 180 degrees, carefully slide back the screen, and remove the remaining two screws.
      询问修复机器人
      添加评论
    5. TomTom VIA 1530 TM Back Replacement: 步骤 5 中的图像 1,3 TomTom VIA 1530 TM Back Replacement: 步骤 5 中的图像 2,3 TomTom VIA 1530 TM Back Replacement: 步骤 5 中的图像 3,3
      • Disconnect the battery and speaker cables.
      • Unlatch the motherboard from the case.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
Cal Poly, Team S12-G2, Banghart Winter 2018 Cal Poly, Team S12-G2, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S12G2
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 24
总计 947
