跳转到主内容
加入维修社区 - 创建账户
TomTom Runner LCD Screen Replacement Guide
你所需要的
    1. TomTom Runner LCD Screen Replacement Guide, Wristband: 步骤 1 中的图像 1,1
      • First, lift the bottom part of the band to start removing the wristband from the button area of the watch.
      添加评论
    2. TomTom Runner LCD Screen Replacement Guide: 步骤 2 中的图像 1,2 TomTom Runner LCD Screen Replacement Guide: 步骤 2 中的图像 2,2
      • Continue to lift up on the band until the screen of the watch becomes loose from the band.
      • You may need to apply a small amount of force downward on the face of the screen.
      • Continue to pull up on the wristband until it is completely off the watch.
      询问修复机器人
      添加评论
    1. TomTom Runner LCD Screen Replacement Guide, Back Panel: 步骤 3 中的图像 1,1
      • Grab the watch once it is separated from the wristband.
      询问修复机器人
      添加评论
    2. TomTom Runner LCD Screen Replacement Guide: 步骤 4 中的图像 1,1
      • Flip over the watch and remove the four 3.0 mm Torx head screws with a T4 Torx head screwdriver.
      询问修复机器人
      添加评论
    3. TomTom Runner LCD Screen Replacement Guide: 步骤 5 中的图像 1,2 TomTom Runner LCD Screen Replacement Guide: 步骤 5 中的图像 2,2
      • Remove the two 3.0 mm Torx screws from the front. Use a T4 Torx screwdriver to remove the screws.
      • The two 3.0 mm Torx screws are painted blue at the end. These screws have screw holders around them that will also need to be removed.
      • Unscrew the screws from the front of the watch casing and the screw holders fall out from the back of the watch casing.
      询问修复机器人
      添加评论
    4. TomTom Runner LCD Screen Replacement Guide: 步骤 6 中的图像 1,2 TomTom Runner LCD Screen Replacement Guide: 步骤 6 中的图像 2,2
      • Gently pull the back panel away from the front panel.
      • Do not to pull too fast or too hard. There are red and black wires connected to the vibrator component that should not be ripped.
      询问修复机器人
      添加评论
    5. TomTom Runner LCD Screen Replacement Guide: 步骤 7 中的图像 1,2 TomTom Runner LCD Screen Replacement Guide: 步骤 7 中的图像 2,2
      • Gently wiggle the black box vibrator component away from the back panel with your fingers or a Spudger tool.
      • Be gentle with the red and black wires. You do not want them to rip or pop out.
      • The vibrator component is the small black box with the silver metal part at end. The black box is glued down, so it will take a little force to free it and it will be sticky.
      询问修复机器人
      添加评论
    1. TomTom Runner LCD Screen Replacement Guide, Front Cover: 步骤 8 中的图像 1,2 TomTom Runner LCD Screen Replacement Guide, Front Cover: 步骤 8 中的图像 2,2
      在这个步骤中使用的工具:
      • Now lift the smaller square of copper off the Front Panel. Use the bent, metal precision tweezers and slide it under the smaller square of copper lining then gently lift it up.
      • You will need to be gentle and pull the copper slowly so that it does not rip.
      询问修复机器人
      添加评论
    2. TomTom Runner LCD Screen Replacement Guide: 步骤 9 中的图像 1,2 TomTom Runner LCD Screen Replacement Guide: 步骤 9 中的图像 2,2
      • Use the bent, metal precision tweezers to remove the thin copper piece from large square silver piece in the Front Casing.
      询问修复机器人
      添加评论
    3. TomTom Runner LCD Screen Replacement Guide: 步骤 10 中的图像 1,1
      • Remove the two 2.0 mm Torx Head screws with the T5 Torx screwdriver.
      询问修复机器人
      添加评论
    4. TomTom Runner LCD Screen Replacement Guide: 步骤 11 中的图像 1,3 TomTom Runner LCD Screen Replacement Guide: 步骤 11 中的图像 2,3 TomTom Runner LCD Screen Replacement Guide: 步骤 11 中的图像 3,3
      • Use your fingers to gently pull the whole green motherboard out of the Front Casing.
      • If you have trouble using your fingers, then use the black Spudger tool.
      询问修复机器人
      添加评论
    1. TomTom Runner LCD Screen Replacement Guide, LCD Screen: 步骤 12 中的图像 1,1
      • Grab the screen attached to the green motherboard.
      询问修复机器人
      添加评论
    2. TomTom Runner LCD Screen Replacement Guide: 步骤 13 中的图像 1,3 TomTom Runner LCD Screen Replacement Guide: 步骤 13 中的图像 2,3 TomTom Runner LCD Screen Replacement Guide: 步骤 13 中的图像 3,3
      • Using the pointed end of the black Spudger tool, gently pry the motherboard away from the screen.
      • The motherboard and screen are very fragile, but the motherboard should pop right off.
      • Once you have the motherboard partially pried off, use your fingers to gently pop it out of the clear, plastic clips holding it in place.
      • Continue to pull the motherboard away from the screen to fully expose the white backing of the screen.
      询问修复机器人
      添加评论
    3. TomTom Runner LCD Screen Replacement Guide: 步骤 14 中的图像 1,3 TomTom Runner LCD Screen Replacement Guide: 步骤 14 中的图像 2,3 TomTom Runner LCD Screen Replacement Guide: 步骤 14 中的图像 3,3
      • Once the white backing of the screen is exposed, carefully flip the two pieces, the motherboard and the screen, over while they are still connected.
      • Look for the small metal piece attached to the motherboard that is wrapped around the front of the screen.
      • Gently slide the screen under and back to free it from the metal piece.
      询问修复机器人
      添加评论
    4. TomTom Runner LCD Screen Replacement Guide: 步骤 15 中的图像 1,1
      • Once free from the Front Casing and the motherboard, you are ready to replace the screen.
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
Texas Tech, Team S8-G6, Bennett Spring 2017 Texas Tech, Team S8-G6, Bennett Spring 2017 的会员
TTU-BENNETT-S17S8G6
4 名成员
创作了21篇指南
8指南评论
Who sells the replacement screens? I can’t find them anywhere online. Do I need to contact TomTom directly?
Erin Espinoza - 回复 分享
Please help where can i buy the lcd
hjcouto - 回复 分享
This article is useless unless you know where to buy the replacement screen!!!!
Kel Needham - 回复 分享
this tutorial is without function because there is no sale of replacement screens. unfortunately
fielbicolor - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 51
总计 10,870
