跳转到主内容
ThinkPad X1 Carbon SSD Replacement
你所需要的
  1. ThinkPad X1 Carbon SSD Replacement, Remove Bottom Cover: 步骤 1 中的图像 1,1
    • Use phillips #2 screwdriver to loosen seven cover screws.
    Don’t forget to backup your data
    Oliver - 回复
  2. ThinkPad X1 Carbon SSD Replacement, Remove Bottom Cover: 步骤 2 中的图像 1,1
    • Use spudger to pop open bottom cover, remove and set aside.
  3. ThinkPad X1 Carbon SSD Replacement, Disconnect Battery: 步骤 3 中的图像 1,1
    • Disconnect the battery connector from the main board by pulling the connector towards the battery.
  4. ThinkPad X1 Carbon SSD Replacement, Remove SSD Screw: 步骤 4 中的图像 1,1
    • Use the # 2 phillips screwdriver and remove the screw holding the SSD in place.
  5. ThinkPad X1 Carbon SSD Replacement, Remove SSD: 步骤 5 中的图像 1,1
    • Remove the SSD by sliding it out of the connector to the right.
    I could be noted, that the M.2-connector has very strong spring, so at least my SSD pops up so hard it bounces the screw if not kept hold of. Also the insertion of SSD should be made in same angle as it comes out, not vertically sliding. The type of M.2 SSD is single-sided SATA, not NVMe.
    TJI - 回复
结论
12等其他人完成本指南。
Mike
于06/23/16注册
1,906 声望
创作了5篇指南
团队
iReconstruction iReconstruction 的会员
Business
1 名成员
创作了16篇指南
8条评论
hi, can advise me which of the latest ssd 256/500 GB ssd's would work on a x1 carbon i5?
hardtail1969 - 回复
Really need to put the version/generation of the x1 carbon.. The gen 1 does not look like this inside and I’m spending way too much time trying to figure out what SSD it will take
Eric Metzger - 回复
Even for new models still can be used. same m.2 drive that might be located in the middle or top right of the device. Once the screws are off it is a very easy process.
jwalker8931 - 回复
I just replaced the SSD on my gen 6 and the steps are so easy: undo 5 screws, open up, undo 1 screw to loosen the M.2 module, replace and put things back together. There is no need to mess around with the battery connection at all.
haivu - 回复
A proper way, yes you need to disconnect the battery. You will learn it a hard way just a minor mistake, will blow your Mother Board and you will remember to disconnect them next time. The instruction is great.
Ryan Chau -
Can someone confirm the m.2 type on these units?
Thomas Keats - 回复
Is anyone aware (before I take mine apart) of whether or not a Gen 7 can accommodate a M.2 SSD fitted with a heatsink? Thanks.
Nhonz - 回复
X1 Carbon Gen 3 20BS here: It could be noted, that the M.2-connector has very strong spring, so at least my SSD pops up so hard it bounces the screw if not kept hold of. Also the insertion of SSD should be made in same angle as it comes out, not vertically sliding. The type of M.2 SSD is single-sided SATA (double-sided bends the connector too much, not enough space for proper fit), not NVMe.
TJI - 回复
添加评论
浏览统计数据:
过去 24 小时: 16
过去 7 天: 79
过去 30 天: 397
总计 48,784
