跳转到主内容
加入维修社区 - 创建账户
ThinkPad Edge E31 Wireless Card Replacement
你所需要的
  1. ThinkPad Edge E31 Wireless Card Replacement, Battery: 步骤 1 中的图像 1,1
    • There are two two locks for the battery, one on the left and one on the right.
    • Slide the left lock to the left.
    询问修复机器人
    添加评论
  2. ThinkPad Edge E31 Wireless Card Replacement: 步骤 2 中的图像 1,1
    • Slide and hold the right battery lock to the right.
    • While holding the right battery lock, slide the battery up to remove it from the laptop.
    询问修复机器人
    添加评论
  3. ThinkPad Edge E31 Wireless Card Replacement, ThinkPad Edge E31 Underside Disassembly: 步骤 3 中的图像 1,1
    • The battery should be removed before accessing any internal components, and you should ground yourself before handling internal components.
    • Unscrew the 5 screws holding the back on. These screws will unscrew from the laptop, but will remain secured to the back plate even when fully loosened. Once unscrewed, the plate can be removed.
    询问修复机器人
    添加评论
  4. ThinkPad Edge E31 Wireless Card Replacement, Wireless Card: 步骤 4 中的图像 1,1
    • The wireless card is located above the Hard drive and RAM on the exposed laptop.
    • There are 2, 4mm long M2 screws holding the wireless card to the laptop. Unscrew the screws.
    询问修复机器人
    添加评论
  5. ThinkPad Edge E31 Wireless Card Replacement: 步骤 5 中的图像 1,1
    • Once the screws are removed, there will be 2 wires attached to the card. These can be easily popped off by hand to fully disconnect the card form the laptop.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Riley
于03/19/17注册
601 声望
创作了6篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 367
