跳转到主内容
加入维修社区 - 创建账户
ThinkPad Edge E31 Screen Replacement
你所需要的
  1. ThinkPad Edge E31 Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • There are two two locks for the battery, one on the left and one on the right.
    • Slide the left lock to the left.
    询问修复机器人
    添加评论
  2. ThinkPad Edge E31 Screen Replacement: 步骤 2 中的图像 1,1
    • Slide and hold the right battery lock to the right.
    • While holding the right battery lock, slide the battery up to remove it from the laptop.
    询问修复机器人
    添加评论
  3. ThinkPad Edge E31 Screen Replacement, Screen: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    • Remove the 4 rubber tabs on the corners of the screen. This can be easily done by twisting them off with the tweezers. The tabs have adhesive on the backs so they can be re-applied later.
    询问修复机器人
    添加评论
  4. ThinkPad Edge E31 Screen Replacement: 步骤 4 中的图像 1,1
    • Under each rubber tab is a 4mm long M2 screw. Remove these screws.
    询问修复机器人
    添加评论
  5. ThinkPad Edge E31 Screen Replacement: 步骤 5 中的图像 1,2 ThinkPad Edge E31 Screen Replacement: 步骤 5 中的图像 2,2
    • There are plastic tabs every couple of inches that hold the bezel on. Wedge the plastic opening tool in the seam between the screen bezel and the edge of the laptop. This will pop the tabs and allow you to remove the bezel.
    • Continue popping the bezel tabs around the edge of the screen until all of them are free and the bezel can be removed.
    询问修复机器人
    添加评论
  6. ThinkPad Edge E31 Screen Replacement: 步骤 6 中的图像 1,1
    • Under the bezel, there are 4, 3mm long M2 screws holding the screen to the hinge. Remove the screws.
    询问修复机器人
    添加评论
  7. ThinkPad Edge E31 Screen Replacement: 步骤 7 中的图像 1,1
    • Place the screen face down on the keyboard. The only connection the screen has to the laptop is now its connection cable.There is a piece of tape covering the screen's connection cable. Using the tweezers, remove this tape.
    询问修复机器人
    添加评论
  8. ThinkPad Edge E31 Screen Replacement: 步骤 8 中的图像 1,1
    • Underneath the tape there is an exposed connection. The connection cable that plugs into the screen has a securing wire lock that locks the connection in place. The locking wire has a piece of tape that secures it in place to the back of the screen. With the tweezers, carefully peel off this tape.
    询问修复机器人
    添加评论
  9. ThinkPad Edge E31 Screen Replacement: 步骤 9 中的图像 1,2 ThinkPad Edge E31 Screen Replacement: 步骤 9 中的图像 2,2
    • Now that the lock is no longer taped down, it can be lifted up so that the cable can be disconnected.
    • Now, unplug the connection cable, and the screen is completely disconnected.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Riley
于03/19/17注册
601 声望
创作了6篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 29
总计 787
