跳转到主内容
加入维修社区 - 创建账户
ThinkPad Edge E31 RAM Replacement
你所需要的
  1. ThinkPad Edge E31 RAM  Replacement, Battery: 步骤 1 中的图像 1,1
    • There are two two locks for the battery, one on the left and one on the right.
    • Slide the left lock to the left.
    询问修复机器人
    添加评论
  2. ThinkPad Edge E31 RAM  Replacement: 步骤 2 中的图像 1,1
    • Slide and hold the right battery lock to the right.
    • While holding the right battery lock, slide the battery up to remove it from the laptop.
    询问修复机器人
    添加评论
  3. ThinkPad Edge E31 RAM  Replacement, ThinkPad Edge E31 Underside Disassembly: 步骤 3 中的图像 1,1
    • The battery should be removed before accessing any internal components, and you should ground yourself before handling internal components.
    • Unscrew the 5 screws holding the back on. These screws will unscrew from the laptop, but will remain secured to the back plate even when fully loosened. Once unscrewed, the plate can be removed.
    询问修复机器人
    添加评论
  4. ThinkPad Edge E31 RAM  Replacement, RAM: 步骤 4 中的图像 1,1
    • The RAM slots are next to the hard drive to the right of the exposed laptop.
    • There are 2 flexible brackets holding each RAM chip in place is.
    • Push these 2 brackets to the sides. This will allow the chips to pop up to a 30° angle.
    询问修复机器人
    添加评论
  5. ThinkPad Edge E31 RAM  Replacement: 步骤 5 中的图像 1,1
    • Once freed from the brackets, the RAM can now be easily pulled out of its slot.
    询问修复机器人
    添加评论
  6. ThinkPad Edge E31 RAM  Replacement: 步骤 6 中的图像 1,1
    • If your laptop has a second RAM chip in the available slot, repeat the previous 2 steps to remove it.
    • If you are going to be putting 2 RAM chips in your laptop, ensure that they are matching makes and models. This will ensure that you avoid any potential issues that may occur by mixing and matching RAM chips.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Riley
于03/19/17注册
601 声望
创作了6篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 26
总计 578
