跳转到主内容
加入维修社区 - 创建账户
ThinkPad Edge E31 Hard Drive Replacement
你所需要的
  1. ThinkPad Edge E31 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • There are two two locks for the battery, one on the left and one on the right.
    • Slide the left lock to the left.
    询问修复机器人
    添加评论
  2. ThinkPad Edge E31 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Slide and hold the right battery lock to the right.
    • While holding the right battery lock, slide the battery up to remove it from the laptop.
    询问修复机器人
    添加评论
  3. ThinkPad Edge E31 Hard Drive Replacement, ThinkPad Edge E31 Underside Disassembly: 步骤 3 中的图像 1,1
    • The battery should be removed before accessing any internal components, and you should ground yourself before handling internal components.
    • Unscrew the 5 screws holding the back on. These screws will unscrew from the laptop, but will remain secured to the back plate even when fully loosened. Once unscrewed, the plate can be removed.
    询问修复机器人
    添加评论
  4. ThinkPad Edge E31 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,1
    • Remember to ground yourself before handing internal components of a laptop.
    • The hard drive is on the bottom left side of the exposed laptop.
    • Remove the 3.5mm long M3 screw securing the hard drive to the laptop.
    询问修复机器人
    添加评论
  5. ThinkPad Edge E31 Hard Drive Replacement: 步骤 5 中的图像 1,2 ThinkPad Edge E31 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • On the left edge of the hard drive there is a plastic tab. Pull up slightly on this tab.
    • Pull the tab to the left to remove the hard drive from the laptop.
    询问修复机器人
    添加评论
  6. ThinkPad Edge E31 Hard Drive Replacement: 步骤 6 中的图像 1,1
    • To remove the hard drive mounting bracket, locate the screws holding it on. There is one, 4mm long M2 screw on each of each on the long edges of the drive, and remove them. This will free the drive from the bracket. The bracket is needed to put the new drive back into the computer.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Riley
于03/19/17注册
601 声望
创作了6篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 22
总计 618
