简介
If the clear plastic case on your claw device is broken or damaged, it can easily be replaced. This required the opening of the top cover of your claw device in order to access the clear plastic panels. Using this easy to follow replacement guide will make case replacement an easy task.
你所需要的
Place The Claw machine in the up-right position with the control knobs facing you.
2等其他人完成本指南。
