跳转到主内容
加入维修社区 - 创建账户
Texas Instruments TI-92 Batteries Replacement
你所需要的
    1. Texas Instruments TI-92 Batteries Replacement, Back Cover: 步骤 1 中的图像 1,3 Texas Instruments TI-92 Batteries Replacement, Back Cover: 步骤 1 中的图像 2,3 Texas Instruments TI-92 Batteries Replacement, Back Cover: 步骤 1 中的图像 3,3
      • The first step to any repair operation is to remove the front cover.
      • Grab the back of the calculator with one hand and the cover with the other.
      • Pull the cover off from one of the sides for easy removal.
      询问修复机器人
      添加评论
    2. Texas Instruments TI-92 Batteries Replacement: 步骤 2 中的图像 1,2 Texas Instruments TI-92 Batteries Replacement: 步骤 2 中的图像 2,2
      • Orientate the calculator with the top facing towards you.
      • Slide the locking tab,found on the top part of the calculator, to the unlock position.
      询问修复机器人
      添加评论
    3. Texas Instruments TI-92 Batteries Replacement: 步骤 3 中的图像 1,2 Texas Instruments TI-92 Batteries Replacement: 步骤 3 中的图像 2,2
      • "Locking Tab"
      • To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
      • Then with the front of the calculator facing down, pull up on the back cover.
      • The calculator should now be orientated with the front facing down, as shown in picture 2.
      询问修复机器人
      添加评论
    1. Texas Instruments TI-92 Batteries Replacement, Batteries: 步骤 4 中的图像 1,3 Texas Instruments TI-92 Batteries Replacement, Batteries: 步骤 4 中的图像 2,3 Texas Instruments TI-92 Batteries Replacement, Batteries: 步骤 4 中的图像 3,3
      • The Batteries are now exposed and the calculator is face down with the back towards you.
      • Remove the bottom batteries by pressing the battery towards you while pulling it out from the far end.
      • If you can not do the previous step with your finger try using a flat ended tool such as an Ipod opening tool.
      • After the bottom battery has been removed push or slide the other(top) battery towards you until it is fully exposed in the battery slot.
      • Now simply remove the battery.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
团队
Cal Poly, Team 15-51, Garner Spring 2010 Cal Poly, Team 15-51, Garner Spring 2010 的会员
CPSU-GARNER-S10S15G51
5 名成员
创作了27篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 57
总计 8,115
