跳转到主内容
加入维修社区 - 创建账户
Texas Instruments TI-83 Plus Individual Keys Replacement
你所需要的
    1. Texas Instruments TI-83 Plus Individual Keys Replacement, Backup Battery: 步骤 1 中的图像 1,2 Texas Instruments TI-83 Plus Individual Keys Replacement, Backup Battery: 步骤 1 中的图像 2,2
      • Remove the battery cover.
      • Remove the AAA batteries from the calculator.
      询问修复机器人
      添加评论
    2. Texas Instruments TI-83 Plus Individual Keys Replacement: 步骤 2 中的图像 1,1
      • Remove the 5mm Philips #00 screw holding backup battery cover.
      • Remove the backup battery cover.
      询问修复机器人
      添加评论
    3. Texas Instruments TI-83 Plus Individual Keys Replacement: 步骤 3 中的图像 1,1
      • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
      • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
      添加评论
    1. Texas Instruments TI-83 Plus Individual Keys Replacement, Back Case: 步骤 4 中的图像 1,1
      • Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
      询问修复机器人
      添加评论
    2. Texas Instruments TI-83 Plus Individual Keys Replacement: 步骤 5 中的图像 1,2 Texas Instruments TI-83 Plus Individual Keys Replacement: 步骤 5 中的图像 2,2
      • Pry back case off. Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
      添加评论
    1. Texas Instruments TI-83 Plus Individual Keys Replacement, Motherboard & Screen: 步骤 6 中的图像 1,2 Texas Instruments TI-83 Plus Individual Keys Replacement, Motherboard & Screen: 步骤 6 中的图像 2,2
      • Keep the screen face-down during this step. Only the motherboard is attached to the face-plate and the screen may fall out.
      • Remove the eight (8) 5mm Philips #00 screws on the motherboard.
      询问修复机器人
      添加评论
    2. Texas Instruments TI-83 Plus Individual Keys Replacement: 步骤 7 中的图像 1,2 Texas Instruments TI-83 Plus Individual Keys Replacement: 步骤 7 中的图像 2,2
      • Carefully remove the motherboard and screen. Grab the board by its side with one hand and the screen with the other. Carefully lift the two parts up.
      • Keep the face-plate face-down to prevent the keys from falling out.
      询问修复机器人
      添加评论
    1. Texas Instruments TI-83 Plus Individual Keys Replacement, Keyboard Mat: 步骤 8 中的图像 1,2 Texas Instruments TI-83 Plus Individual Keys Replacement, Keyboard Mat: 步骤 8 中的图像 2,2
      • Remove light gray rubber keyboard mat.
      • Keep your calculator face down to ensure the individual keys do not fall out.
      询问修复机器人
      添加评论
    2. Texas Instruments TI-83 Plus Individual Keys Replacement: 步骤 9 中的图像 1,1
      • Clean the contacts on the keyboard with a soft cloth.
      询问修复机器人
      添加评论
    1. Texas Instruments TI-83 Plus Individual Keys Replacement, Individual Keys: 步骤 10 中的图像 1,2 Texas Instruments TI-83 Plus Individual Keys Replacement, Individual Keys: 步骤 10 中的图像 2,2
      在这个步骤中使用的工具:
      • Use tweezers to remove one key at a time.
      • Be sure to keep them organized if you are taking out multiple keys.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Jared
于10/02/12注册
156 声望
创作了2篇指南
团队
Cal Poly, Team 18-37, Regan Fall 2012 Cal Poly, Team 18-37, Regan Fall 2012 的会员
CPSU-REGAN-F12S18G37
5 名成员
创作了23篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 61
总计 5,492
