跳转到主内容
加入维修社区 - 创建账户
Tengda S5 Plus Home Button Replacement
你所需要的
    1. Tengda S5 Plus Home Button Replacement, Back Panel: 步骤 1 中的图像 1,1
      • Place the phone screen-side down.
      询问修复机器人
      添加评论
    2. Tengda S5 Plus Home Button Replacement: 步骤 2 中的图像 1,2 Tengda S5 Plus Home Button Replacement: 步骤 2 中的图像 2,2
      • Using your fingernail or any prying tool (we used the Metal Spudger), begin to pry away the back panel starting at the bottom of the phone.
      • Continue to work your way around the phone counterclockwise until you can pull the back cover off.
      询问修复机器人
      添加评论
    1. Tengda S5 Plus Home Button Replacement, Battery: 步骤 3 中的图像 1,1
      • Remove the battery by placing your thumb in the slot, pushing the battery up and pulling it out.
      询问修复机器人
      添加评论
    1. Tengda S5 Plus Home Button Replacement, Home Button: 步骤 4 中的图像 1,1
      • Unscrew the twelve 3 mm screws from the back panel using a Phillips #00 screwdriver.
      • Keep these screws in a safe place. They are very small and easy to lose.
      询问修复机器人
      添加评论
    2. Tengda S5 Plus Home Button Replacement: 步骤 5 中的图像 1,2 Tengda S5 Plus Home Button Replacement: 步骤 5 中的图像 2,2
      • Using the plastic opening tool, create a small gap between the front screen and the metal casing. Slide the plastic opening tool around the phone counterclockwise to make this gap around the entire phone.
      • Once the screen is separated from the back panel, pull the two pieces apart.
      询问修复机器人
      添加评论
    3. Tengda S5 Plus Home Button Replacement: 步骤 6 中的图像 1,1
      在这个步骤中使用的工具:
      • Lay your device with the screen faced down.
      • Using tweezers, lift the two pieces of yellow tape holding the wire in place.
      询问修复机器人
      添加评论
    4. Tengda S5 Plus Home Button Replacement: 步骤 7 中的图像 1,2 Tengda S5 Plus Home Button Replacement: 步骤 7 中的图像 2,2
      • Using the tweezers again, grasp the wire and free it from the crevice.
      • This will provide slack for you to work with the lower motherboard.
      询问修复机器人
      添加评论
    5. Tengda S5 Plus Home Button Replacement: 步骤 8 中的图像 1,3 Tengda S5 Plus Home Button Replacement: 步骤 8 中的图像 2,3 Tengda S5 Plus Home Button Replacement: 步骤 8 中的图像 3,3
      • Remove the silver tape that holds the lower motherboard to the front panel of the phone.
      询问修复机器人
      添加评论
    6. Tengda S5 Plus Home Button Replacement: 步骤 9 中的图像 1,2 Tengda S5 Plus Home Button Replacement: 步骤 9 中的图像 2,2
      • Using your fingers, or the Metal Spudger, disconnect the black cable connector.
      • The cable connector should easy snap out with little force.
      添加评论
    7. Tengda S5 Plus Home Button Replacement: 步骤 10 中的图像 1,3 Tengda S5 Plus Home Button Replacement: 步骤 10 中的图像 2,3 Tengda S5 Plus Home Button Replacement: 步骤 10 中的图像 3,3
      • Using your fingers, slide the lower motherboard towards you.
      • The lower motherboard will still be attached to the front panel by a red and blue cable on the left side and a long silver wire on the right side, but you should now have visibility of the home button.
      询问修复机器人
      添加评论
    8. Tengda S5 Plus Home Button Replacement: 步骤 11 中的图像 1,2 Tengda S5 Plus Home Button Replacement: 步骤 11 中的图像 2,2
      • Clean away any dirt from the back side of the lower motherboard, underneath the charging port.
      • Using tweezers, grasp and remove the home button.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Kenny Levy
于04/20/15注册
128 声望
撰写一个指南
团队
Cal Poly, Team 14-9, Amido Spring 2015 Cal Poly, Team 14-9, Amido Spring 2015 的会员
CPSU-AMIDO-S15S14G9
4 名成员
创作了20篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 34
总计 723
