跳转到主内容
加入维修社区 - 创建账户
Technique - Test the Battery
你所需要的
    1. Technique - Test the Battery, Technique - Test the Battery: 步骤 1 中的图像 1,3 Technique - Test the Battery, Technique - Test the Battery: 步骤 1 中的图像 2,3 Technique - Test the Battery, Technique - Test the Battery: 步骤 1 中的图像 3,3
      • Remove back cover by applying pressure and sliding up towards the top of the phone.
      询问修复机器人
      添加评论
    2. Technique - Test the Battery: 步骤 2 中的图像 1,2 Technique - Test the Battery: 步骤 2 中的图像 2,2
      • Remove the battery by lifting from slot on the right hand side.
      询问修复机器人
      添加评论
    3. Technique - Test the Battery: 步骤 3 中的图像 1,2 Technique - Test the Battery: 步骤 3 中的图像 2,2
      • Use Multimeter to test the voltage of the battery.
      • Put the black lead into ground slot of multimeter and the red lead into the V(ohm)mA slot.
      • Place the red and black leads to the two outside metal plate, each on opposite sides, on the battery as shown.
      • Check that the voltage displayed on the multimeter matches closely to the voltage defined on the battery. Normally 3.7 V.
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Melinda Phan
于04/17/11注册
438 声望
创作了9篇指南
团队
Cal Poly, Team 9-64, Walters Spring 2011 Cal Poly, Team 9-64, Walters Spring 2011 的会员
CPSU-WALTERS-S11S9G64
5 名成员
创作了45篇指南
2指南评论
Hello one the question was tablet not telephone and it's really vague how you guys explain these things you need to go to work on your site
Roger Slater - 回复 分享
yes,not tablet with battery removal difficult
paulbeames7 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 64
总计 11,241
