跳转到主内容
加入维修社区 - 创建账户
Tagital T10 Touch Screen Replacement
你所需要的
    1. Tagital T10 Touch Screen Replacement, Touch Screen: 步骤 1 中的图像 1,1
      • Always make sure your device is completely powered off before performing repairs
      • Remove the two 4mm screws at the top of the device.
      • Set these aside and be careful not to lose them, as well as all other screws that you remove.
      询问修复机器人
      添加评论
    2. Tagital T10 Touch Screen Replacement: 步骤 2 中的图像 1,1
      • Carefully remove the back cover by using a plastic prying tool, moving all the way around the perimeter of the tablet.
      • Set the back cover aside
      • The speakers are attached to the inside back cover, and are connected by wires to the motherboard of the tablet. Carefully set the back cover aside so that you do not rip the wires free.
      询问修复机器人
      添加评论
    3. Tagital T10 Touch Screen Replacement: 步骤 3 中的图像 1,1
      • The display screen is the silver box that the battery and motherboard sit on. It sits snugly against the underside of the touch screen.
      • Remove all of the 4mm screws that attach the display screen to the back of the touch screen with brackets.
      询问修复机器人
      添加评论
    4. Tagital T10 Touch Screen Replacement: 步骤 4 中的图像 1,2 Tagital T10 Touch Screen Replacement: 步骤 4 中的图像 2,2
      • Remove all of the 4mm screws that attach the motherboard to the rest of the device.
      • One screw is located beneath the black tape that holds the rear-facing camera in place. Peel the tape up to access it.
      询问修复机器人
      添加评论
    5. Tagital T10 Touch Screen Replacement: 步骤 5 中的图像 1,2 Tagital T10 Touch Screen Replacement: 步骤 5 中的图像 2,2
      • Locate the 2 ZIF connectors.
      • Flip up the black tab to release the two filaments, so that they are no longer connected to the motherboard.
      询问修复机器人
      添加评论
    6. Tagital T10 Touch Screen Replacement: 步骤 6 中的图像 1,2 Tagital T10 Touch Screen Replacement: 步骤 6 中的图像 2,2
      • Locate the notification light on the upper left corner of the device.
      • Gently pull on the wires to remove the light from its housing.
      询问修复机器人
      添加评论
    7. Tagital T10 Touch Screen Replacement: 步骤 7 中的图像 1,1
      • Remove the motherboard from the back of the display screen.
      • Some wires are still attached to the device so carefully set it to the side
      询问修复机器人
      添加评论
    8. Tagital T10 Touch Screen Replacement: 步骤 8 中的图像 1,2 Tagital T10 Touch Screen Replacement: 步骤 8 中的图像 2,2
      • Begin lifting the display screen out of its housing with a plastic prying tool, sliding it around the perimeter of the screen.
      • It may be helpful to use two prying tools at the same time.
      询问修复机器人
      添加评论
    9. Tagital T10 Touch Screen Replacement: 步骤 9 中的图像 1,1
      • Completely remove the display screen from the touchscreen.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
USF Tampa, Team 14-5, Eyestone Fall 2016 USF Tampa, Team 14-5, Eyestone Fall 2016 的会员
USFT-EYESTONE-F16S14G5
4 名成员
创作了15篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 30
总计 1,778
