跳转到主内容
加入维修社区 - 创建账户
Tagital T10 Camera Replacement
你所需要的
    1. Tagital T10 Camera Replacement, Camera: 步骤 1 中的图像 1,1
      • Always make sure your device is completely powered off before performing repairs.
      • Remove the two 4 mm Phillips head screws at the top of the device.
      询问修复机器人
      添加评论
    2. Tagital T10 Camera Replacement: 步骤 2 中的图像 1,1
      • Carefully remove the back cover by using a plastic opening tool, moving all the way around the perimeter of the tablet.
      • Set the back cover aside.
      • The speakers are attached to the inside back cover, and are connected by wires to the motherboard of the tablet. Be careful not to rip these free when removing the back.
      询问修复机器人
      添加评论
    3. Tagital T10 Camera Replacement: 步骤 3 中的图像 1,1
      • Pull the black tape away so that the rear-facing camera is no longer attached to the device.
      询问修复机器人
      添加评论
    4. Tagital T10 Camera Replacement: 步骤 4 中的图像 1,1
      在这个步骤中使用的工具:
      • Pull off the plastic camera cover with the tweezers so that the front-facing camera can move freely.
      询问修复机器人
      添加评论
    5. Tagital T10 Camera Replacement: 步骤 5 中的图像 1,1
      • Locate the small ZIF connector that connects to the cameras.
      • Use the plastic prying tool to pull up the black tab, so that the filament is released. Carefully pull the filament out so it is moving freely.
      • The camera can now be lifted from the device.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Destin Dawsy
于09/26/16注册
328 声望
创作了2篇指南
团队
USF Tampa, Team 14-5, Eyestone Fall 2016 USF Tampa, Team 14-5, Eyestone Fall 2016 的会员
USFT-EYESTONE-F16S14G5
4 名成员
创作了15篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 40
总计 531
