跳转到主内容
加入维修社区 - 创建账户
Table Lamp Cord Replacement
你所需要的
    1. Table Lamp Cord Replacement, Cord: 步骤 1 中的图像 1,2 Table Lamp Cord Replacement, Cord: 步骤 1 中的图像 2,2
      • Required materials: AAMP rewire kit, light bulb (not pictured), lamp shade (optional).
      • The AAMP lamp rewire kit should include a new cord, a socket shell, a socket interior and bottle adaptors. (Refer the second image to view the contents of the kit).
      询问修复机器人
      添加评论
    2. Table Lamp Cord Replacement: 步骤 2 中的图像 1,1
      • Caution! Before removing the lightbulb, ensure that the lamp is unplugged.
      • Cut the old lamp wire using scissors.
      • Remove the cord from the lamp.
      • Dispose the cord.
      询问修复机器人
      添加评论
    3. Table Lamp Cord Replacement: 步骤 3 中的图像 1,2 Table Lamp Cord Replacement: 步骤 3 中的图像 2,2
      • Thread the new wire through the hole on the bottom of the lamp. Pull it out through the top of the lamp base. (Refer the first image to get a better understanding.)
      • Place the old check ring on top of the lamp with the wire threaded through it. (Refer the second image to see the check ring.)
      询问修复机器人
      添加评论
    4. Table Lamp Cord Replacement: 步骤 4 中的图像 1,2 Table Lamp Cord Replacement: 步骤 4 中的图像 2,2
      • Place the lock nut at the end of the lamp nipple and turn it clockwise.
      • Thread the lock nut a quarter of the way through the lamp nipple.
      询问修复机器人
      添加评论
    5. Table Lamp Cord Replacement: 步骤 5 中的图像 1,2 Table Lamp Cord Replacement: 步骤 5 中的图像 2,2
      • Ensure that the lamp cord sticks through the top of the lamp base.
      • Insert the lamp nipple and the lock nut into the bottle, in such a way that one-fourth inch of the lamp nipple faces up.
      询问修复机器人
      添加评论
    6. Table Lamp Cord Replacement: 步骤 6 中的图像 1,1
      • Insert the socket in the lamp nipple.
      • Tighten the socket by turning it clockwise until it reaches the lock nut.
      询问修复机器人
      添加评论
    7. Table Lamp Cord Replacement: 步骤 7 中的图像 1,1
      • Pull either ends of the wire so that you have about 2-3 inches of the wire separated.
      询问修复机器人
      添加评论
    8. Table Lamp Cord Replacement: 步骤 8 中的图像 1,1
      • Tie an underwriter's knot in the two separated pieces of wire.
      • How to tie the knot: Form a loop using the first wire. Take the second wire and form a loop around the first. Pass the tail of the second wire through the loop of the first.
      询问修复机器人
      添加评论
    9. Table Lamp Cord Replacement: 步骤 9 中的图像 1,1
      • Check both the conductors at the end of the wire. Find the ribbed conductor and wrap it around the silver-colored screw. Connect the other conductor to the brass-colored screw.
      • Tighten both of the screws in a clockwise direction. Make sure the conductors are securely under the screw head.
      询问修复机器人
      添加评论
    10. Table Lamp Cord Replacement: 步骤 10 中的图像 1,2 Table Lamp Cord Replacement: 步骤 10 中的图像 2,2
      • Place the socket shell (with paper liner) over the socket interior. Snap it into correct position. Listen for clicks to make sure that the shell is locked properly.
      • The socket should snap together to form one piece.
      询问修复机器人
      添加评论
    11. Table Lamp Cord Replacement: 步骤 11 中的图像 1,1
      • Caution: Be sure that the rewired lamp is not plugged at this step.
      • Insert the new light bulb into the socket. Plug the cord and turn it on.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Aysha Vear
于11/04/15注册
195 声望
撰写一个指南
团队
University of Maine, Team 1-3, Diaz Fall 2015 University of Maine, Team 1-3, Diaz Fall 2015 的会员
UMAINE-DIAZ-F15S1G3
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 50
总计 8,446
