跳转到主内容
TOZO HT2 Main Board Replacement
你所需要的
  1. TOZO HT2 Main Board Replacement, Ear Pad: 步骤 1 中的图像 1,3 TOZO HT2 Main Board Replacement, Ear Pad: 步骤 1 中的图像 2,3 TOZO HT2 Main Board Replacement, Ear Pad: 步骤 1 中的图像 3,3
    • Firmly hold the headphone housing in one hand to hold the device steady and put the other hand on the ear pad you intend to replace.
    • Note: Do not force the ear pad to come off or you risk breaking the tabs that keep the pads in place.
  2. TOZO HT2 Main Board Replacement: 步骤 2 中的图像 1,3 TOZO HT2 Main Board Replacement: 步骤 2 中的图像 2,3 TOZO HT2 Main Board Replacement: 步骤 2 中的图像 3,3
    • Twist the ear cover counterclockwise until it pops off.
    • Repeat for the other ear pad if necessary.
  3. TOZO HT2 Main Board Replacement, Main Board: 步骤 3 中的图像 1,1
    • Use a Phillips screwdriver to remove each of the four screws on the speaker cover.
    • Lift the cover off without pulling on the wires inside and set it to the side to access the circuit board.
  4. TOZO HT2 Main Board Replacement: 步骤 4 中的图像 1,2 TOZO HT2 Main Board Replacement: 步骤 4 中的图像 2,2
    • Use a Philips screwdriver to remove the screws that secure the main board.
    • Carefully lift the board out of the headphones, making sure to not pull on and damage the wires inside.
  5. TOZO HT2 Main Board Replacement: 步骤 5 中的图像 1,1
    • Use flush cutters to cut the wires as close as possible to their main board connections.
  6. TOZO HT2 Main Board Replacement: 步骤 6 中的图像 1,1
    • Soldering how to
    • Use this guide to reattach the wires to the circuit board.
    • HANDLE WITH CARE: Soldering Iron becomes VERY Hot (Up to or above 400°C or 800°F).
    • Wear eye protection while soldering and only do so in a well ventilated room and/or with a fume extractor.
    • Remove all possible fire hazards from the surrounding area.
    • Keep all animals and children out of the room.
结论
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 22
总计 287
