跳转到主内容
加入维修社区 - 创建账户
TCL Stylus Battery Replacement
你所需要的
    • Press and hold the Power button for 2 seconds.
    • Then, select "Power off".
    询问修复机器人
    添加评论
  1. TCL Stylus Battery Replacement, Remove back panel: 步骤 2 中的图像 1,3 TCL Stylus Battery Replacement, Remove back panel: 步骤 2 中的图像 2,3 TCL Stylus Battery Replacement, Remove back panel: 步骤 2 中的图像 3,3
    • Insert a jimmy tool into the casing to create a gap.
    • Then, put a plastic pick in the gap and remove the jimmy tool.
    • Finally, lift up to remove the panel.
    询问修复机器人
    添加评论
  2. TCL Stylus Battery Replacement, Remove plastic shielding: 步骤 3 中的图像 1,2 TCL Stylus Battery Replacement, Remove plastic shielding: 步骤 3 中的图像 2,2
    • Remove the 10 Phillips screws holding the plastic shielding from the motherboard.
    • Then, grab a pick and put in in the slot show on picture 2.
    • You should then be able to lift the rest of it off.
    询问修复机器人
    添加评论
  3. TCL Stylus Battery Replacement, Unplug battery: 步骤 4 中的图像 1,2 TCL Stylus Battery Replacement, Unplug battery: 步骤 4 中的图像 2,2
    • With your fingernail, lift up the battery connector.
    询问修复机器人
    添加评论
  4. TCL Stylus Battery Replacement, Unpeel tape: 步骤 5 中的图像 1,2 TCL Stylus Battery Replacement, Unpeel tape: 步骤 5 中的图像 2,2
    • Unpeel the tape holding the battery.
    询问修复机器人
    添加评论
  5. TCL Stylus Battery Replacement, Remove battery: 步骤 6 中的图像 1,2 TCL Stylus Battery Replacement, Remove battery: 步骤 6 中的图像 2,2
    • Pull on the sticker located on the middle of the left side (colored green) of the battery to remove it.
    • NOTE: The pull tab may have resistance.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Lee Hunt
于12/08/16注册
1,288 声望
创作了7篇指南
5指南评论
Lg syluis is a non removeable battery
katherine hicks - 回复 分享
It's just not easily removable. But every battery in every phone is removable if you know what you're doing. That's why the pictures explain. You come in here getting all worked up but your ignorance really shows. Obviously you don't have the intelligence to attempt this kind of repair, so go crochet me some mittens or something.
Cj Gabbard - 回复 分享
Its a non removeable battery phone,unless u control it with a chiness &&^&@@ dumb ass move battery
No removeable
Thanks for the information. At least you do not have to deal with heating the phone in order to loosen adhesive which is common with other phone models. Six steps to get to the battery is way easier than going through over 20 steps to do the same thing.
e s - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 15
过去 30 天: 56
总计 2,685
