跳转到主内容
加入维修社区 - 创建账户
T-Mobile Sparq SIM Card Replacement
你所需要的
  1. T-Mobile Sparq SIM Card Replacement, Battery: 步骤 1 中的图像 1,1
    • If you're looking at your phone from the front, feel the upper left hand rounded corner. You'll notice a thin opening between the front of the phone and the back cover.
    • Flip the phone over (as in the picture) and use a spudger or your finger to gently separate the back cover from the phone.
    询问修复机器人
    添加评论
  2. T-Mobile Sparq SIM Card Replacement: 步骤 2 中的图像 1,1
    • Once the back cover has been removed you can see a small groove above the center of the battery. The arrow on the battery is pointing to it.
    • Insert the tip of your finger into the groove and gently lift the battery from the case.
    询问修复机器人
    添加评论
  3. T-Mobile Sparq SIM Card Replacement, SIM Card: 步骤 3 中的图像 1,1
    • Once the battery has been removed the SIM card is easily accessible. Press your finger gently on top of the exposed SIM card and slide it in the direction of the battery compartment until it comes out.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
LeAnn Lewis
于04/07/18注册
539 声望
创作了4篇指南
团队
IUPUI, Team S3-G3, Wilson Spring 2018 IUPUI, Team S3-G3, Wilson Spring 2018 的会员
IUPUI-WILSON-S18S3G3
3 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 34
总计 520
