跳转到主内容
Sweatshirt Hoodie Grommets Replacement
你所需要的
  1. Sweatshirt Hoodie Grommets Replacement, Grommets: 步骤 1 中的图像 1,2 Sweatshirt Hoodie Grommets Replacement, Grommets: 步骤 1 中的图像 2,2
    • Grab the end of the hoodie of the string.
    • Pull the string towards yourself until it is out of the hoodie completely.
  2. Sweatshirt Hoodie Grommets Replacement: 步骤 2 中的图像 1,3 Sweatshirt Hoodie Grommets Replacement: 步骤 2 中的图像 2,3 Sweatshirt Hoodie Grommets Replacement: 步骤 2 中的图像 3,3
    • Use the seam ripper to tear the seam on the hoodie open.
    • Use scissors as necessary to cut excess thread.
    • Continue this process until the seam is open enough to put the grommet tool in. There should be a hole about 1"-2" long.
    • Seam ripper may cause injury if handled incorrectly.
  3. Sweatshirt Hoodie Grommets Replacement: 步骤 3 中的图像 1,1
    • Place the top section of the grommet over the desired hole.
  4. Sweatshirt Hoodie Grommets Replacement: 步骤 4 中的图像 1,2 Sweatshirt Hoodie Grommets Replacement: 步骤 4 中的图像 2,2
    • Flip the hole over and place the bottom piece of the grommet over the cylindrical section of the top piece.
    • Grab your grommet pliers and locate the side with the cone shaped nub. Make sure that the side with the nub is facing against the bottom piece of the grommet.
  5. Sweatshirt Hoodie Grommets Replacement: 步骤 5 中的图像 1,2 Sweatshirt Hoodie Grommets Replacement: 步骤 5 中的图像 2,2
    • Align the grommet pliers with both pieces of the grommet.
    • Squeeze the pliers with moderate pressure until the grommet becomes attached to the hoodie securely.
  6. Sweatshirt Hoodie Grommets Replacement: 步骤 6 中的图像 1,1
    • Thread a sewing needle with matching colored thread to mend the ripped area.
    • Follow How to Use a Needle Threader if you are unsure how to do this.
  7. Sweatshirt Hoodie Grommets Replacement: 步骤 7 中的图像 1,3 Sweatshirt Hoodie Grommets Replacement: 步骤 7 中的图像 2,3 Sweatshirt Hoodie Grommets Replacement: 步骤 7 中的图像 3,3
    • Re-attach the ripped area using your preferred sewing technique.
    • Use a scissor to cut off excess threads after finish sewing.
    • Follow How to Hand Sew A Small Hole in Clothing if you are unsure how to do this.
  8. Sweatshirt Hoodie Grommets Replacement: 步骤 8 中的图像 1,1
终点
Haiming Dong
于01/31/24注册
157 声望
撰写一个指南
团队
UC Davis, Team 4-5, Andersen Winter 2024 UC Davis, Team 4-5, Andersen Winter 2024 的会员
UCD-ANDERSEN-W24S4G5
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 43
总计 183
