跳转到主内容
Sweatpants Drawstring Replacement
你所需要的
  1. Sweatpants Drawstring Replacement, Drawstring: 步骤 1 中的图像 1,1
  2. Sweatpants Drawstring Replacement: 步骤 2 中的图像 1,3 Sweatpants Drawstring Replacement: 步骤 2 中的图像 2,3 Sweatpants Drawstring Replacement: 步骤 2 中的图像 3,3
    • Insert the blunt end of the Drawstring Threader in the hole of the sweatpants.
  3. Sweatpants Drawstring Replacement: 步骤 3 中的图像 1,1
    • Push the Drawstring Threader through the hole and fabric of the sweatpants.
    • Use your hand to pull the fabric and push the Drawstring Threader simultaneously.
  4. Sweatpants Drawstring Replacement: 步骤 4 中的图像 1,1
    • Gather the fabric together to move the Drawstring Threader through the hollow band of the sweatpants.
  5. Sweatpants Drawstring Replacement: 步骤 5 中的图像 1,1
    • Push and pull the blunt end of the Drawstring Threader through the second hole of the sweatpants.
  6. Sweatpants Drawstring Replacement: 步骤 6 中的图像 1,2 Sweatpants Drawstring Replacement: 步骤 6 中的图像 2,2
    • Pull the blunt side of the Drawstring Threader.
    • Pull the threader until the drawstring and the Threader have emerged through the second hole.
    • Keep pulling until the threader is removed from the sweatpants.
  7. Sweatpants Drawstring Replacement: 步骤 7 中的图像 1,1
    • Remove the drawstring from the Drawstring Threader.
  8. Sweatpants Drawstring Replacement: 步骤 8 中的图像 1,1
    • Hold the top of the sweatpants fabric.
    • Pull the drawstrings to match in equal length.
  9. Sweatpants Drawstring Replacement: 步骤 9 中的图像 1,1
    • Tie the drawstrings together in a bow.
    • Tying the drawstrings will prevent another occurrence.
终点
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 19
过去 30 天: 88
总计 2,858
