跳转到主内容
How to fix an unthreaded drawstring
你所需要的
  1. How to fix an unthreaded drawstring, How to fix an unthreaded drawstring: 步骤 1 中的图像 1,3 How to fix an unthreaded drawstring, How to fix an unthreaded drawstring: 步骤 1 中的图像 2,3 How to fix an unthreaded drawstring, How to fix an unthreaded drawstring: 步骤 1 中的图像 3,3
    • Take the loose end of the drawstring, and cut any frayed material.
    • Take the cotter pin and thread the drawstring through the spilt end of the cotter pin.
    • Slide the drawstring to the eye of the cotter pin.
  2. How to fix an unthreaded drawstring: 步骤 2 中的图像 1,3 How to fix an unthreaded drawstring: 步骤 2 中的图像 2,3 How to fix an unthreaded drawstring: 步骤 2 中的图像 3,3
    • Feed the cotter pin through the drawstring casing.
    • The casing will vary on each garment. In this case the drawstring casing is visible on the exterior of the garment, but it may be on the inside of your garment.
  3. How to fix an unthreaded drawstring: 步骤 3 中的图像 1,2 How to fix an unthreaded drawstring: 步骤 3 中的图像 2,2
    • Scrunch the drawstring casing over the cotter pin and pull the cotter pin through the casing.
    • Continue scrunching and sliding the cotter pin through the casing.
    • This takes a bit of finesse; just stick with it.
  4. How to fix an unthreaded drawstring: 步骤 4 中的图像 1,2 How to fix an unthreaded drawstring: 步骤 4 中的图像 2,2
    • Pull the cotter pin out through the end of the drawstring casing.
    • Pull the drawstring through, until the loose end of the drawstring comes out.
  5. How to fix an unthreaded drawstring: 步骤 5 中的图像 1,3 How to fix an unthreaded drawstring: 步骤 5 中的图像 2,3 How to fix an unthreaded drawstring: 步骤 5 中的图像 3,3
    • Insert the cotter pin—still holding the drawstring—into the drawstring hold.
    • In this case, the drawstring hold is a small hole in the garment. The drawstring hold is just the place where the drawstring will be sewn to the garment. This may vary from garment to garment.
    • Pinch the drawstring inside of the drawstring hold.
    • While holding the drawstring, pull the cotter pin out, sliding the drawstring out through the spilt in the pin.
  6. How to fix an unthreaded drawstring: 步骤 6 中的图像 1,2 How to fix an unthreaded drawstring: 步骤 6 中的图像 2,2
    • While holding the drawstring in the hold, mark where the drawstring will be sewn with tailor's chalk.
    • If you aren't sure where to sew the drawstring, feel for the other end of the drawstring. In most garments, the drawcord is symmetrical.
    • Sew several passes along the chalk line, being sure to catch the drawstring.
终点
2等其他人完成本指南。
Brittany McCrigler
于03/05/12注册
89,128 声望
创作了131篇指南
团队
iFixit iFixit 的会员
Staff
140 名成员
创作了18,074篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 90
过去 30 天: 414
总计 34,094
