跳转到主内容
加入维修社区 - 创建账户
Swann Doorphone Video Intercom Wire Replacement
你所需要的
    1. Swann Doorphone Video Intercom Wire Replacement, Wire: 步骤 1 中的图像 1,3 Swann Doorphone Video Intercom Wire Replacement, Wire: 步骤 1 中的图像 2,3 Swann Doorphone Video Intercom Wire Replacement, Wire: 步骤 1 中的图像 3,3
      • Flip the monitor of the Swann Doorphone over so that the underside is facing up.
      • Grip the sides of the black rectangular frame where they extend outwards and pull down.
      • After pulling down, pull the frame towards you to remove it from the monitor.
      询问修复机器人
      添加评论
    2. Swann Doorphone Video Intercom Wire Replacement: 步骤 2 中的图像 1,3 Swann Doorphone Video Intercom Wire Replacement: 步骤 2 中的图像 2,3 Swann Doorphone Video Intercom Wire Replacement: 步骤 2 中的图像 3,3
      • Using the JIS #0 screwdriver, unscrew the 2 mm screw in terminal 1 with the blue wire underneath.
      • Pull the blue wire out from beneath the metal plate.
      • Be careful when removing the screw from terminal 1, the metal plate behind the screw is not connected and may fall off.
      询问修复机器人
      添加评论
    3. Swann Doorphone Video Intercom Wire Replacement: 步骤 3 中的图像 1,3 Swann Doorphone Video Intercom Wire Replacement: 步骤 3 中的图像 2,3 Swann Doorphone Video Intercom Wire Replacement: 步骤 3 中的图像 3,3
      • Flip the outdoor camera over so that the underside is facing up.
      • Remove the back cover by grabbing the sides of the camera and pulling towards your body.
      询问修复机器人
      添加评论
    4. Swann Doorphone Video Intercom Wire Replacement: 步骤 4 中的图像 1,3 Swann Doorphone Video Intercom Wire Replacement: 步骤 4 中的图像 2,3 Swann Doorphone Video Intercom Wire Replacement: 步骤 4 中的图像 3,3
      • With the back cover of the outdoor camera off, press the first gray square button with blue wire down.
      • While pressing the gray square button, remove the blue wire from the first opening under the button.
      • Be sure to remove the same color wire for the outdoor camera as was used for the indoor video intercom.
      • In this guide, we are using the blue wire in terminal 1 for the audio. As a recommendation; * Use the blue wire in terminal 1 for the audio wire. * Use the brown wire in terminal 2 for the ground wire. * Use the green wire in terminal 3 for the video wire. * Use the black wire in terminal 4 for the power wire.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Emily Stenke
于02/14/18注册
555 声望
创作了4篇指南
团队
USF Tampa, Team S2-G4, Eyestone Spring 2018 USF Tampa, Team S2-G4, Eyestone Spring 2018 的会员
USFT-EYESTONE-S18S2G4
4 名成员
创作了10篇指南
5指南评论
Have found wires what do I do now to fix the problem?
Norman Stuckey - 回复 分享
Not much good telling me which wiresEmily. I need to know what to do next
Emily, Anyone home? Still no answer EMILY where are you???
Is the unit stuffed or can it be repaired
Emily Emily where are you?
Just when i thought you were going to be useful you have disappeared
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 43
总计 2,525
