跳转到主内容
加入维修社区 - 创建账户
Swagtron T3 Wheel Replacement
你所需要的
  1. Swagtron T3 Wheel Replacement, Cover: 步骤 1 中的图像 1,2 Swagtron T3 Wheel Replacement, Cover: 步骤 1 中的图像 2,2
    • Make sure the hoverboard is completely powered off and unplugged from any outlets.
    • Flip the Swagtron so that the footpads are facing the ground.
    • Unscrew the sixteen 9.4 mm Phillips #1 machine screws on the side of the Swagtron that is now facing upwards.
    询问修复机器人
    添加评论
  2. Swagtron T3 Wheel Replacement: 步骤 2 中的图像 1,3 Swagtron T3 Wheel Replacement: 步骤 2 中的图像 2,3 Swagtron T3 Wheel Replacement: 步骤 2 中的图像 3,3
    • Be careful with the small blue capacitors indicated by the orange box. There are many of these capacitors in the device.
    • Slowly lift the backside cover.
    • Both sides lift up the same way, but the motherboard is under one side and the battery is under the other.
    • Detach the four cables connected to the cover by pinching the connector clips and pulling the cables out:
    • Three cables on the motherboard side.
    • Two red cables with white connectors and one white cable with a white connector.
    • One yellow cable with a black connector on the battery side.
    • After detachment, you should be able to completely remove the backside cover.
    询问修复机器人
    添加评论
  3. Swagtron T3 Wheel Replacement, Wheel: 步骤 3 中的图像 1,1
    • Unscrew the six 11.2 mm Phillips machine screws from the inside of the wheel.
    • You many need to spray a thin lubricant, such as PB Blaster, directly onto each of the six screw points to loosen them.
    询问修复机器人
    添加评论
  4. Swagtron T3 Wheel Replacement: 步骤 4 中的图像 1,2 Swagtron T3 Wheel Replacement: 步骤 4 中的图像 2,2
    • Pull the wheel off of its base.
    • The wheel has a strong magnetic connection to the base, so separating the them will require a lot of force.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Cal Poly, Team S13-G3, Forte Spring 2017 Cal Poly, Team S13-G3, Forte Spring 2017 的会员
CPSU-FORTE-S17S13G3
4 名成员
创作了4篇指南
3指南评论
Hi,
my girl Swagtron T6 wheel is flat. Probably it is a nail hole. We are faraway from US, so I have to do it by myself. Can I get the wheel out for tire repairing?
Can you help me please?
Thanks
Susana Arzuaga - 回复 分享
Can't the wheel off
Christopher Primo - 回复 分享
I have a T6 Swagtron and I am struggling to get the wheel off. Are these magnets really that strong? It feels like there is something else holding the wheel in place. I tried prying it but doesn’t seem like its doing enough.
photostudiomilk - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 50
总计 4,689
