跳转到主内容
加入维修社区 - 创建账户
Swagtron T3 Gyroscope Replacement
你所需要的
  1. Swagtron T3 Gyroscope Replacement, Cover: 步骤 1 中的图像 1,2 Swagtron T3 Gyroscope Replacement, Cover: 步骤 1 中的图像 2,2
    • Make sure the hoverboard is completely powered off and unplugged from any outlets.
    • Flip the Swagtron so that the footpads are facing the ground.
    • Unscrew the sixteen 9.4 mm Phillips #1 machine screws on the side of the Swagtron that is now facing upwards.
    询问修复机器人
    添加评论
  2. Swagtron T3 Gyroscope Replacement: 步骤 2 中的图像 1,3 Swagtron T3 Gyroscope Replacement: 步骤 2 中的图像 2,3 Swagtron T3 Gyroscope Replacement: 步骤 2 中的图像 3,3
    • Be careful with the small blue capacitors indicated by the orange box. There are many of these capacitors in the device.
    • Slowly lift the backside cover.
    • Both sides lift up the same way, but the motherboard is under one side and the battery is under the other.
    • Detach the four cables connected to the cover by pinching the connector clips and pulling the cables out:
    • Three cables on the motherboard side.
    • Two red cables with white connectors and one white cable with a white connector.
    • One yellow cable with a black connector on the battery side.
    • After detachment, you should be able to completely remove the backside cover.
    询问修复机器人
    添加评论
  3. Swagtron T3 Gyroscope Replacement, Gyroscope: 步骤 3 中的图像 1,1
    • The gyroscope is a blue rectangular circuit board on top of a white base and is closest to the wheel.
    • Detach the four cables connecting the gyroscope to the hoverboard by pinching the connector clips and pulling the cables out:
    • Three red and black cables with white connectors.
    • One multicolored cable with a black connector.
    询问修复机器人
    添加评论
  4. Swagtron T3 Gyroscope Replacement: 步骤 4 中的图像 1,1
    • Uncrew the four 7.2 mm Phillips #1 self-drilling screws connecting the blue gyroscope to the white plastic holding piece.
    询问修复机器人
    添加评论
  5. Swagtron T3 Gyroscope Replacement: 步骤 5 中的图像 1,2 Swagtron T3 Gyroscope Replacement: 步骤 5 中的图像 2,2
    • Cut the plastic cable tie holding the cables together with utility scissors.
    • Disconnect the blue/green cable from the blue/white cable by pinching the connector clips and pulling the cables apart.
    询问修复机器人
    添加评论
  6. Swagtron T3 Gyroscope Replacement: 步骤 6 中的图像 1,1
    • Gently lift the blue gyroscope off of the white plastic holder piece.
    • After reassembling the Swagtron with the new gyroscope, check to make sure your Swagtron is balancing properly.
    • If it is still unbalanced, repeat all steps in this guide with the gyroscope by the other wheel.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
Cal Poly, Team S13-G3, Forte Spring 2017 Cal Poly, Team S13-G3, Forte Spring 2017 的会员
CPSU-FORTE-S17S13G3
4 名成员
创作了4篇指南
3指南评论
Where can one buy the new gyroscope?
Mike - 回复 分享
Where is the best place to buy the gyroscope for the T3?
I see Ebay sells complete kits with motherboards and all.
Are they compatible?
Mike - 回复 分享
where can I buy new gyroscope
roccovalletta - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 47
总计 5,523
