跳转到主内容
加入维修社区 - 创建账户
Swagtron T3 Battery Replacement
你所需要的
  1. Swagtron T3 Battery Replacement, Cover: 步骤 1 中的图像 1,2 Swagtron T3 Battery Replacement, Cover: 步骤 1 中的图像 2,2
    • Make sure the hoverboard is completely powered off and unplugged from any outlets.
    • Flip the Swagtron so that the footpads are facing the ground.
    • Unscrew the sixteen 9.4 mm Phillips #1 machine screws on the side of the Swagtron that is now facing upwards.
    询问修复机器人
    添加评论
  2. Swagtron T3 Battery Replacement: 步骤 2 中的图像 1,3 Swagtron T3 Battery Replacement: 步骤 2 中的图像 2,3 Swagtron T3 Battery Replacement: 步骤 2 中的图像 3,3
    • Be careful with the small blue capacitors indicated by the orange box. There are many of these capacitors in the device.
    • Slowly lift the backside cover.
    • Both sides lift up the same way, but the motherboard is under one side and the battery is under the other.
    • Detach the four cables connected to the cover by pinching the connector clips and pulling the cables out:
    • Three cables on the motherboard side.
    • Two red cables with white connectors and one white cable with a white connector.
    • One yellow cable with a black connector on the battery side.
    • After detachment, you should be able to completely remove the backside cover.
    询问修复机器人
    添加评论
  3. Swagtron T3 Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Unscrew the four 9.4 mm Phillips #1 machine screws attaching the battery to the base of the Swagtron T3.
    询问修复机器人
    添加评论
  4. Swagtron T3 Battery Replacement: 步骤 4 中的图像 1,2 Swagtron T3 Battery Replacement: 步骤 4 中的图像 2,2
    • Detach the two cables connecting the battery to the Swagtron by pinching the connector clips and pulling the cables apart:
    • One red and black cable with a yellow connector.
    • One blue cable with a black connector.
    添加评论
  5. Swagtron T3 Battery Replacement: 步骤 5 中的图像 1,2 Swagtron T3 Battery Replacement: 步骤 5 中的图像 2,2
    • Remove the battery by pulling it out from under the cables.
    添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
团队
Cal Poly, Team S13-G3, Forte Spring 2017 Cal Poly, Team S13-G3, Forte Spring 2017 的会员
CPSU-FORTE-S17S13G3
4 名成员
创作了4篇指南
11指南评论
where can i get a replacement battery?
rob - 回复 分享
Where can I get a replacement battery?
rob - 回复 分享
I can’t find a battery with the two wire harnesses coming out of the pack. Where can I order one?
Jeff Johnson - 回复 分享
Where Can I purchase a replacement batter for the T3
Leandre - June 18
Leandre Thornton - 回复 分享
Swagtron doesn’t sell the silver battery (even if you email them) I bought one from HoverboardRepair.com and it worked. Only difference is the small wire doesn’t come on the new battery but my hoverboard has worked just fine and I replaced the battery months ago.
Daniel Moravec - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 16
过去 30 天: 60
总计 8,910
