跳转到主内容
加入维修社区 - 创建账户
SwagTron T1 Wheel Replacement
你所需要的
    1. SwagTron T1 Wheel Replacement, Back Panels: 步骤 1 中的图像 1,1
      • Ensure that the SwagTron is off.
      • Turn the SwagTron upside down to see the underside.
      询问修复机器人
      添加评论
    2. SwagTron T1 Wheel Replacement: 步骤 2 中的图像 1,3 SwagTron T1 Wheel Replacement: 步骤 2 中的图像 2,3 SwagTron T1 Wheel Replacement: 步骤 2 中的图像 3,3
      • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
      • The screws are tightly in place. It will take effort to screw them out.
      • The panel is still attached to the SwagTron by wires that go to the motherboard.
      • Carefully lift the panels off
      添加评论
    3. SwagTron T1 Wheel Replacement: 步骤 3 中的图像 1,3 SwagTron T1 Wheel Replacement: 步骤 3 中的图像 2,3 SwagTron T1 Wheel Replacement: 步骤 3 中的图像 3,3
      • Follow the wires from the panels to the motherboard.
      • You may need to cut any zip ties that are holding the wires together.
      • There is one connection on the battery side and three on the other side that must be removed.
      • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
      • Your back panels are now completely removed.
      添加评论
    1. SwagTron T1 Wheel Replacement, Wheel: 步骤 4 中的图像 1,3 SwagTron T1 Wheel Replacement, Wheel: 步骤 4 中的图像 2,3 SwagTron T1 Wheel Replacement, Wheel: 步骤 4 中的图像 3,3
      • Using your Phillips #2 screwdriver, remove the four 1cm screws that attach the gyroscope and its black case to the hoverboard.
      • Carefully remove this component and set it off to the side.
      询问修复机器人
      添加评论
    2. SwagTron T1 Wheel Replacement: 步骤 5 中的图像 1,3 SwagTron T1 Wheel Replacement: 步骤 5 中的图像 2,3 SwagTron T1 Wheel Replacement: 步骤 5 中的图像 3,3
      • Using your H 6.0 allen wrench, remove the four 20mm black bolts shown in the picture.
      • Take off the iron plate holding the wheel in place.
      • Remove the Motor/Wheel and set it aside close by to the hoverboard.
      • The wires from the Motor/Wheel should still be connected to the motherboard.
      • These bolts are very tight, it may be difficult to remove them. Try using a tool with a long handle.
      询问修复机器人
      添加评论
    3. SwagTron T1 Wheel Replacement: 步骤 6 中的图像 1,3 SwagTron T1 Wheel Replacement: 步骤 6 中的图像 2,3 SwagTron T1 Wheel Replacement: 步骤 6 中的图像 3,3
      在这个步骤中使用的工具:
      • Slide the protective plastic off the connectors on the marked wires (green, blue, and yellow) using your hands or a set of tweezers.
      • The connectors on the wires of your hoverboard may be different from those shown in the pictures on the left due to differences in manufacturing.
      • Separate the set of marked green, blue, and yellow wires from their connectors.
      询问修复机器人
      添加评论
    4. SwagTron T1 Wheel Replacement: 步骤 7 中的图像 1,3 SwagTron T1 Wheel Replacement: 步骤 7 中的图像 2,3 SwagTron T1 Wheel Replacement: 步骤 7 中的图像 3,3
      • Finally separate the last connector shown on the left.
      • Your wheel is completely removed; slide in a new Motor/Wheel into the slot and follow the previous steps in reverse order.
      • Make sure the replacement wheel is snug. Neither rubbing on the outer rim nor on the side of the hoverboard.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
Teagan Allen
于04/18/17注册
432 声望
创作了2篇指南
团队
Cal Poly, Team S17-G5, Banghart Spring 2017 Cal Poly, Team S17-G5, Banghart Spring 2017 的会员
CPSU-BANGHART-S17S17G5
4 名成员
创作了5篇指南
3指南评论
Where do you get replacement wheels?
Elizabeth Schumacher - 回复 分享
Where can we find replacement wheels?
Liz Vance - 回复 分享
Mine won't stop beeping?? Fully charged.
Rachael Anderson - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 15
过去 30 天: 41
总计 6,595
