跳转到主内容
加入维修社区 - 创建账户
SwagTron T1 Gyroscope Replacement
你所需要的
  1. SwagTron T1 Gyroscope Replacement, Back Panels: 步骤 1 中的图像 1,1
    • Ensure that the SwagTron is off.
    • Turn the SwagTron upside down to see the underside.
    询问修复机器人
    添加评论
  2. SwagTron T1 Gyroscope Replacement: 步骤 2 中的图像 1,3 SwagTron T1 Gyroscope Replacement: 步骤 2 中的图像 2,3 SwagTron T1 Gyroscope Replacement: 步骤 2 中的图像 3,3
    • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
    • The screws are tightly in place. It will take effort to screw them out.
    • The panel is still attached to the SwagTron by wires that go to the motherboard.
    • Carefully lift the panels off
    添加评论
  3. SwagTron T1 Gyroscope Replacement: 步骤 3 中的图像 1,3 SwagTron T1 Gyroscope Replacement: 步骤 3 中的图像 2,3 SwagTron T1 Gyroscope Replacement: 步骤 3 中的图像 3,3
    • Follow the wires from the panels to the motherboard.
    • You may need to cut any zip ties that are holding the wires together.
    • There is one connection on the battery side and three on the other side that must be removed.
    • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
    • Your back panels are now completely removed.
    添加评论
  4. SwagTron T1 Gyroscope Replacement, Gyroscope: 步骤 4 中的图像 1,2 SwagTron T1 Gyroscope Replacement, Gyroscope: 步骤 4 中的图像 2,2
    • Disconnect the gyroscope by disconnecting the wires attached to it. These wires are black, green, blue and red.
    询问修复机器人
    添加评论
  5. SwagTron T1 Gyroscope Replacement: 步骤 5 中的图像 1,1
    • Using your Phillips #2 screwdriver, remove the four 8mm screws marked in red from the gyroscope.
    询问修复机器人
    添加评论
  6. SwagTron T1 Gyroscope Replacement: 步骤 6 中的图像 1,3 SwagTron T1 Gyroscope Replacement: 步骤 6 中的图像 2,3 SwagTron T1 Gyroscope Replacement: 步骤 6 中的图像 3,3
    • Carefully remove the gyroscope component from the SwagTron.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
9等其他人完成本指南。
Teagan Allen
于04/18/17注册
432 声望
创作了2篇指南
团队
Cal Poly, Team S17-G5, Banghart Spring 2017 Cal Poly, Team S17-G5, Banghart Spring 2017 的会员
CPSU-BANGHART-S17S17G5
4 名成员
创作了5篇指南
5指南评论
I cannot find a Swagtron T1 replacement gyroscope anywhere on the internet. Any help would be extremely appreciated!! Thank you!
Gavin Hosler - 回复 分享
Amazon.com Keyword: CertiCable
Jesse Griffis - 回复 分享
Where do you get the replacement?
Brittany Conner - 回复 分享
Can’t find gyroscope for a t5 hover board please help.
jbswearingen70739 - 回复 分享
I just got mine today and after the first hour I ran into a shoe and then I tried recalibrating it but it was no use. If someone knows what’s going on please tell me! Thank you :)
Elia Leon - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 47
总计 8,338
