跳转到主内容
Surface Laptop Studio Battery Replacement
你所需要的
  1. Surface Laptop Studio Battery Replacement, Lower Case: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    • Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
  2. Surface Laptop Studio Battery Replacement: 步骤 2 中的图像 1,2 Surface Laptop Studio Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the two rubber feet on the lower case with an opening tool.
  3. Surface Laptop Studio Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the two screws with a T3 Torx screwdriver.
  4. Surface Laptop Studio Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the seven screws securing the lower case with a T3 Torx screwdriver.
  5. Surface Laptop Studio Battery Replacement: 步骤 5 中的图像 1,2 Surface Laptop Studio Battery Replacement: 步骤 5 中的图像 2,2
    • Lift the lower case gently and set it above the device.
    • Take care not to strain the battery cable as you move the lower case.
  6. Surface Laptop Studio Battery Replacement, Surface Laptop Studio Battery Disconnection: 步骤 6 中的图像 1,2 Surface Laptop Studio Battery Replacement, Surface Laptop Studio Battery Disconnection: 步骤 6 中的图像 2,2
    • Disconnect the battery cable by lifting the pull tab until it "clicks."
  7. Surface Laptop Studio Battery Replacement, Battery: 步骤 7 中的图像 1,2 Surface Laptop Studio Battery Replacement, Battery: 步骤 7 中的图像 2,2
    • Pull the pull tabs to release the adhesive securing the battery.
    • Remove the battery.
    • You will need to reattach the new battery with adhesive.
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.c
另外一个人完成了本指南。
6指南评论
Where can I find a Surface Studio Laptop battery? Microsoft seems to have been out of stock for a while now.
Omar Abouelseoud - 回复
Are the rubber feet re-attachable to the laptop after repairs?
Any link to buy the battery ?
Alberto Guinea (Shlenderman) - 回复
The what you need section should also mention Surface Laptop Studio Cosmetic Plate - Genuine, possibly as an optional part.
Ronno Das - 回复
Great point, Ronno! We added that to the parts list. Thanks for your comment.
Connor Bassolino -
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 118
过去 30 天: 572
总计 11,852
