跳转到主内容
加入维修社区 - 创建账户
Supersonic Matrix SC-91MID Back Cover Replacement
你所需要的
  1. Supersonic Matrix SC-91MID Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,1
    • To begin, insert the plastic opening tool between the display and back cover and apply force until the back cover comes free from the device.
    询问修复机器人
    添加评论
  2. Supersonic Matrix SC-91MID Back Cover Replacement: 步骤 2 中的图像 1,3 Supersonic Matrix SC-91MID Back Cover Replacement: 步骤 2 中的图像 2,3 Supersonic Matrix SC-91MID Back Cover Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    • Carefully remove orange ribbons from the motherboard by opening the small plastic flaps and pulling with tweezers.
    • This will disconnect the front part of the tablet from the back entirely. Set it safely aside and continue
    询问修复机器人
    添加评论
  3. Supersonic Matrix SC-91MID Back Cover Replacement: 步骤 3 中的图像 1,2 Supersonic Matrix SC-91MID Back Cover Replacement: 步骤 3 中的图像 2,2
    • To remove the battery, use the plastic opening tool to pry one corner off of the battery and gently move the opening tool down to pull up one side of the battery.
    • The battery is glued down, so some force may be required to remove it from the back cover.
    询问修复机器人
    添加评论
  4. Supersonic Matrix SC-91MID Back Cover Replacement: 步骤 4 中的图像 1,2 Supersonic Matrix SC-91MID Back Cover Replacement: 步骤 4 中的图像 2,2
    • To remove the speakers, use the plastic opening tool to gently pry the speaker from the back cover, then use the tweezers to remove them fully.
    询问修复机器人
    添加评论
  5. Supersonic Matrix SC-91MID Back Cover Replacement: 步骤 5 中的图像 1,3 Supersonic Matrix SC-91MID Back Cover Replacement: 步骤 5 中的图像 2,3 Supersonic Matrix SC-91MID Back Cover Replacement: 步骤 5 中的图像 3,3
    • To remove the motherboard, start by unscrewing the three (3) small Phillips head screws using a 1.5 mm Phillips head (Phillips #000) screwdriver.
    • The small red washers must be kept along with the screws when reassembling the device, make sure you store them safely until reassembling.
    • The motherboard has soldered connections to the battery, speakers, and the charging indicator LED. Be careful when pulling the motherboard from the back cover because these parts will come along with it.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
IUPUI, Team S1-G1, Wilson Spring 2018 IUPUI, Team S1-G1, Wilson Spring 2018 的会员
IUPUI-WILSON-S18S1G1
5 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 30
总计 457
