跳转到主内容
加入维修社区 - 创建账户
Super Nintendo Power Switch Replacement
你所需要的
  1. Super Nintendo Power Switch Replacement, Outer Case: 步骤 1 中的图像 1,1
    • Remove the six screws located on the underside of the system using the Gamebit 4.5mm screwdriver.
    添加评论
  2. Super Nintendo Power Switch Replacement: 步骤 2 中的图像 1,3 Super Nintendo Power Switch Replacement: 步骤 2 中的图像 2,3 Super Nintendo Power Switch Replacement: 步骤 2 中的图像 3,3
    • Carefully flip the unit back over.
    • Locate the seam. Lift and separate the upper half of the case from the lower half of the case.
    询问修复机器人
    添加评论
  3. Super Nintendo Power Switch Replacement, Power Switch: 步骤 3 中的图像 1,1
    • Remove the two 11.7 mm Phillips #2 screws connecting the power switch to the motherboard.
    添加评论
  4. Super Nintendo Power Switch Replacement: 步骤 4 中的图像 1,2 Super Nintendo Power Switch Replacement: 步骤 4 中的图像 2,2
    • The power switch is connected to the motherboard near the top left of the console.
    • Carefully pull the connector from its socket on the motherboard. You may need to wiggle it out as you pull.
    • Do not detach the connector by pulling on the wires. This could damage the wires or the socket.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
16等其他人完成本指南。
团队
Cal Poly, Team 4-47, Amido Fall 2010 Cal Poly, Team 4-47, Amido Fall 2010 的会员
CPSU-AMIDO-F10S4G47
4 名成员
创作了25篇指南
2指南评论
Any tips on how to tell if it's the power switch that needs replacing vs something else?
TopShopGames - 回复 分享
Look at it for any signs of physical damage, if you don't see any noticeable issues that you can fix then you can try cutting the two wires stripping off the ends of them, and very carefully touching the wires together while its plugged in. BE EXTREMELY CAREFUL WHILE DOING THIS DO NOT TOUCH THE EXPOSED WIRE. If you notice it turn on, immediately stop touching the wires together and unplug the console. This means that the switch itself is broken. If it doesn't turn on, stop touching the wire together and unplug the console. This means that it's likely a power cable issue.
Anders Hoff - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 34
过去 30 天: 138
总计 26,668
