跳转到主内容
加入维修社区 - 创建账户
Step Guide To Install KDZ Firmware Using LG Flash Tool
    • Download the LG flash tool from lgflash.com and extract it on your Windows PC and launch the application
    询问修复机器人
    添加评论
    • Boot your mobile device into download mode by power of the device and holding the Volume Up button.
    询问修复机器人
    添加评论
    • Connet it to the pc using a proper USB cable.
    询问修复机器人
    添加评论
    • Then it is the time for you to load the kdz firmware file into LG Flash Tool window on your PC. Click on the browse button at the end of the 'Select KDZ file' line.
    询问修复机器人
    添加评论
    • Once you selected the KDZ file Click on CSE Flash button to start the flashing process Remember: The application consists of two different flashing options as CSE and Normal. CSE method wipes away the all the date available on your device But the normal method does not. If you want to upgrade from a stock firmware, selest normal
    询问修复机器人
    添加评论
    • Hit on the start button to proceed. it may be asked for administrator permissions for some LG program on your PC, if just accept it. Select the appropriate language.
    添加评论
    • Keep in mind not to tick the Smartphone upgrade checkbox, it’s for Windows Mobile phones, not your LG device running on Android. Finally, You can start the flashing process. Wait Until it does 100%.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
15等其他人完成本指南。
1指南评论
Got a step by step to downgrade to 10 from 13 on the LG v60 thinq 5g? Phone is from ATT
Keith Kilpatrick - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 60
过去 30 天: 334
总计 31,134
