跳转到主内容
加入维修社区 - 创建账户
SteelSeries Nimbus+ Triggers Replacement
你所需要的
  1. SteelSeries Nimbus+ Triggers Replacement, Remove the phone mount: 步骤 1 中的图像 1,2 SteelSeries Nimbus+ Triggers Replacement, Remove the phone mount: 步骤 1 中的图像 2,2
    • Use your fingers to remove the phone mount by pulling it straight out of the controller.
    询问修复机器人
    添加评论
  2. SteelSeries Nimbus+ Triggers Replacement, Remove the sticker: 步骤 2 中的图像 1,1
    • Use your fingers to remove the sticker located on the back cover of the Nimbus+.
    • If you have trouble removing the sticker heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath.
    询问修复机器人
    添加评论
  3. SteelSeries Nimbus+ Triggers Replacement, Unscrew the back cover: 步骤 3 中的图像 1,1
    • Use a Y1 Tri-point screwdriver to remove the five 9.1 mm-long screws securing the back cover.
    询问修复机器人
    添加评论
  4. SteelSeries Nimbus+ Triggers Replacement, Insert an opening pick: 步骤 4 中的图像 1,2 SteelSeries Nimbus+ Triggers Replacement, Insert an opening pick: 步骤 4 中的图像 2,2
    • The back cover is held in place by plastic clips.
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the right controller handle.
    询问修复机器人
    添加评论
  5. SteelSeries Nimbus+ Triggers Replacement, Release the plastic clips: 步骤 5 中的图像 1,2 SteelSeries Nimbus+ Triggers Replacement, Release the plastic clips: 步骤 5 中的图像 2,2
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the right edge.
    询问修复机器人
    添加评论
  6. SteelSeries Nimbus+ Triggers Replacement, Insert an opening pick: 步骤 6 中的图像 1,2 SteelSeries Nimbus+ Triggers Replacement, Insert an opening pick: 步骤 6 中的图像 2,2
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the left controller handle.
    询问修复机器人
    添加评论
  7. SteelSeries Nimbus+ Triggers Replacement, Release the plastic clips: 步骤 7 中的图像 1,2 SteelSeries Nimbus+ Triggers Replacement, Release the plastic clips: 步骤 7 中的图像 2,2
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the left edge.
    询问修复机器人
    添加评论
  8. SteelSeries Nimbus+ Triggers Replacement, Unfold the back cover assembly: 步骤 8 中的图像 1,3 SteelSeries Nimbus+ Triggers Replacement, Unfold the back cover assembly: 步骤 8 中的图像 2,3 SteelSeries Nimbus+ Triggers Replacement, Unfold the back cover assembly: 步骤 8 中的图像 3,3
    • Carefully fold the back cover assembly to the top of the SteelSeries Nimbus+ and bring it in an 90 degree angle.
    • Do not try to remove the back cover assembly all the way yet! It is still connected to mainboard.
    询问修复机器人
    添加评论
  9. SteelSeries Nimbus+ Triggers Replacement, Disconnect the battery cable: 步骤 9 中的图像 1,3 SteelSeries Nimbus+ Triggers Replacement, Disconnect the battery cable: 步骤 9 中的图像 2,3 SteelSeries Nimbus+ Triggers Replacement, Disconnect the battery cable: 步骤 9 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of blunt nose tweezers to disconnect the battery cable from the mainboard.
    询问修复机器人
    添加评论
  10. SteelSeries Nimbus+ Triggers Replacement, Remove the back cover assembly: 步骤 10 中的图像 1,1
    • Remove the back cover assembly.
    询问修复机器人
    添加评论
  11. SteelSeries Nimbus+ Triggers Replacement, Unscrew the board: 步骤 11 中的图像 1,1
    • Use a Phillips screwdriver to remove the two 7.0 mm-long screws securing the board.
    询问修复机器人
    添加评论
  12. SteelSeries Nimbus+ Triggers Replacement, Disconnect the thumbstick board: 步骤 12 中的图像 1,3 SteelSeries Nimbus+ Triggers Replacement, Disconnect the thumbstick board: 步骤 12 中的图像 2,3 SteelSeries Nimbus+ Triggers Replacement, Disconnect the thumbstick board: 步骤 12 中的图像 3,3
    • Disconnect the thumbstick board by pulling it straight out its socket on the mainboard.
    询问修复机器人
    添加评论
  13. SteelSeries Nimbus+ Triggers Replacement, Remove the board: 步骤 13 中的图像 1,1
    • Remove the board with the thumbsticks from the mainboard.
    询问修复机器人
    添加评论
  14. SteelSeries Nimbus+ Triggers Replacement, Unscrew the mainboard: 步骤 14 中的图像 1,1
    • Use a Phillips screwdriver to remove the five 7.0 mm-long screws securing the mainboard to the front assembly.
    询问修复机器人
    添加评论
  15. SteelSeries Nimbus+ Triggers Replacement, Lift up the mainboard: 步骤 15 中的图像 1,3 SteelSeries Nimbus+ Triggers Replacement, Lift up the mainboard: 步骤 15 中的图像 2,3 SteelSeries Nimbus+ Triggers Replacement, Lift up the mainboard: 步骤 15 中的图像 3,3
    • Use your fingers to lift up the mainboard from the front case.
    • Remove the mainboard.
    询问修复机器人
    添加评论
  16. SteelSeries Nimbus+ Triggers Replacement, Unscrew the triggers: 步骤 16 中的图像 1,1
    • Use a Phillips screwdriver to remove the four 7.0 mm screws securing the triggers on the motherboard.
    询问修复机器人
    添加评论
  17. SteelSeries Nimbus+ Triggers Replacement, Release the right trigger: 步骤 17 中的图像 1,2 SteelSeries Nimbus+ Triggers Replacement, Release the right trigger: 步骤 17 中的图像 2,2
    • Pull the right trigger straight out to slide it off of the rails securing it to the button connector on the motherboard.
    询问修复机器人
    添加评论
  18. SteelSeries Nimbus+ Triggers Replacement, Release the left trigger: 步骤 18 中的图像 1,2 SteelSeries Nimbus+ Triggers Replacement, Release the left trigger: 步骤 18 中的图像 2,2
    • Pull the left trigger straight out to slide it off of the rails securing it to the button connector on the motherboard.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Adriana Zwink
于12/18/19注册
67,669 声望
创作了167篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了28,230篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 27
总计 647
